  New Posts New Posts RSS Feed - Choke stove question
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Topic: Choke stove question
    Posted: 29-December-2013 at 1:55AM
Hi Guys
I have a 72 351CJ engine with the original carb. Does anyone know what connects the choke stove pipe to the carb and where? Im referring to the pipe that is directed toward the back of the engine. I would post a pic but I have a hard time getting pictures to this site.
Thanks
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
64 Galaxie country sedan
1972 GTS Q CODE
1972 GTS Q CODE BLACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-December-2013 at 7:32AM
the ones i recall seeing, like you described, look like a tranny cooler line,  thread onto the choke module on the right side of the carb, and connected to the exhaust manifold. (if i remember correctly)
 as far as posting pics: go to how to post pics at the top of the forums, scroll down towards the bottom, and use the tomi method, it work for me!
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 29-December-2013 at 2:34PM
Factory carb has this plastic piece on back side.
Unfortunately I don't have any pictures showing the tubes installed!  I'll have to pull out the original pieces from the cougar and snap a picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 29-December-2013 at 2:35PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2013 at 8:26AM
Hi Mike
Thanks for the picture. I have a metal tube that faces the rear of the block that is connected to the stove piece. I saw in another post that it looks like it should connect to that plastic looking l shaped fitting at the rear top of your carb. I would think it would be a metal tube that connects to that because of the heat from the stove. Any idea what the tube would be called or where to find?
Thanks,Steve
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2013 at 12:01PM
NPD sells the tubes. the one that comes from the stove and goes towards the back connects to the plastic piece with a piece of vacuum line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2013 at 12:13PM
Ok thanks. I need the plastic piece also. Ill see if they have that to. Thanks for the help.
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2013 at 3:47PM
nobody has the plastic piece.  I think its made of unobtanium.  If I happen across a good used one i snatch it up.  Nothing as of late.
This page was generated in 0.095 seconds.
