  New Posts New Posts RSS Feed - Clutch not returning.
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: Clutch not returning.
    Posted: 27-December-2022 at 7:26AM
Hello forum….a small problem……clutch goes down, but doesnt return…..any ideas?
If I lift the clutch pedal with my hand (or foot), it pops back up to normal position.
I have not changed anything……..only greased the bushings…
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2022 at 8:23AM
Isn't there a return spring on the pedal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2022 at 10:20AM
Yes, there is. But, the pedal still stays down…..
I will try the adjusting the adjuster a bit..
Strange..it worked perfectly fine before gettin’ greased…🤠
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2022 at 11:19AM
 watch the action carefully push it by hand while watching under there it could be something overcentering??? there maybe a spring on the pedal and another on the clutch fork... watch for worn bushings and linkage
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2022 at 1:42PM
Definitely feels like the pedal is over-centering…….
Edited by Anderslober - 27-December-2022 at 1:53PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2022 at 4:26PM
Wrong throw-out bearing?
Weak finger springs?
Wrong return-spring?
Is there a pedal-stop that’s missing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2022 at 5:54PM
The whole setup is completely original and was working fine. The only thing I did was grease the bushings. I did this when I had the transmission out. Thats it.
I changed nothing on the tranny either…..same clutch, throwout bearing and fork(just new dust boot)
I will fidget with it some more today…….thanks for all the ideas. I will report back…👍
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2022 at 12:52AM
Well, then it sounds like it’s coming back out again to see what you missed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2022 at 1:24AM
I had a good close look at the clutch setup today. The adjuster was definitely iffy. The pin was just sliding on the threads!😵 No adjustment possible. Quite worn too. Zbar and bushings were good.I hope this was the problem….👍
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2022 at 2:03AM
Well yeah…… that might do it——-
