  New Posts New Posts RSS Feed - Coil questions
Coil questions
Grantorinosport351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Topic: Coil questions
    Posted: 03-November-2013 at 12:09PM
Had this problem previously when the 351 was in the torino, but where does the positive wire to the coil go? And how many volts are put out to it? I can't try to start it now as I don't have an exaust system on it, but I would like to get it done
~Bryan
72 gts h-code (formal roof)
67falcon
04 f250 ''the great white''
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 1:58PM
if i understand your question correctly - the positive wire to the coil goes to the + terminal of the coil  the - terminal connects to the distributor ,  the positive wire runs to the ignition switch which has power when the key is in the on position (usually about 8 volts,  12volts when key is held in the start position)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 2:02PM
Thanks a lot Johnny, you don't happen to know which wire on the switch it is do you?
Edited by Grantorinosport351 - 03-November-2013 at 2:03PM
~Bryan
67falcon
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 2:41PM
Bryan,
We have a copy of the 73 Wire Diagram Manual (WDM) which will show you the wiring of the coil and ignition switch:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 2:43PM
Thanks a lot.
~Bryan
67falcon
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 2:46PM
If your car has electronic ignition than it will not have the +12V at start up, only the normal (the option was on points cars and was to help ignition on the weaker systems). The + wire for the coil is a resistance wire and that is what regulates the +12 to about +8 as californiajohnny has advised.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 2:49PM
looking in the book and looking at my old column-- on the switch the row of terminals closest to the side with the mounting bolts (drivers side) it wound be the 2nd terminal up from the firewall end if you have the switch off and can look in at the terminals it's marked I1 (you could only see that with the wire connector plug off) the 3rd terminal up on the same side is the bypass (12volts at start) terminal. as far as the wire color i don't know, i would have to try and look under my dash.   hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 3:02PM
in looking at the schematic that scott just posted:  it should be a red with a light green stripe (that does sound familiar for the ignition  wire color and also shows you bypass circit wire color being brown with a pink stripe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 6:15PM
Thanks guys this helped a lot!
Edited by Grantorinosport351 - 03-November-2013 at 6:17PM
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 6:19PM
So what I am looking for and all I need to know is that I need the red and green wire connected to the coil?
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2013 at 1:54AM
Ok I dug around this morning before leaving for school, and found the wire!! It was cut off underneath the high rise intake and tested it with the switch on and off and it works! So this wire kicks on 12 volts then constantly runs 8? And 8 is the right amount for this coil? I had a light tester, I will test the voltage when I get home.
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2013 at 2:02AM
Also the wire was red and green directly from the coil to a connector (right above the motor near the wiper motor) then in the connector it changes to a solid red wire that runs into the fire wall, from then on I am unsure, but that may just be on my chero,but I am pretty sure the wires are all stock.
~Bryan
67falcon
