  New Posts New Posts RSS Feed - Coolant in Oil
Coolant in Oil
AuHunter78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AuHunter78 Quote  Post ReplyReply Direct Link To This Post Topic: Coolant in Oil
    Posted: 03-April-2023 at 4:56AM
 I have a 65 Ford F100 with a 72 Gran Torino 302, and I am kind of lost at figuring out how coolant is getting into my oil. The color of the mix on the dipstick, pcv and breather cap is white. The temp stays cool with no over heating at all. I replaced both heads, gaskets (fel-pro set), mahle bolt set (to torque spec), water pump and thermostat. I did a pressure test and the results are good. I also used an inspection camera through the spark plug holes after I drove it for awhile, but no coolant is visible on piston heads or in the cylinders. So I believe it probably isn't a blown head gasket. Can a bad, cracked or warped intake be the culprit? Or should I dive deep into the water pump area/timing cover etc? There is no oil cooler as far as I can see, so I am ruling that out.
AUHUNTER78
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-April-2023 at 2:48PM
check the spark plugs for a super clean (steam cleaned) plug, it's a dead give-away that coolant is getting into that cylinder. the front timing cover and the coolant crossover passage of the intake manifold can also be sources of coolant intrusion into the crank case. or a cracked casting? cast iron is tough but the unfortunate reality is that cylinder heads crack sometimes, between valve seats and also in the valve spring seat area under the valve covers. did you retorque the head gaskets after some heat cycles? any chance a front cover bolt hole in the block had some old sealer down in the hole and blew out the casting when you put it back together?
you found the milkshake in the engine, then replaced the heads and it's still making a milkshake?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2023 at 11:52AM
How long does it hold pressure when you pressure test the coolant system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AuHunter78 Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2023 at 12:15PM
Thank you for the replies. First off, the plugs have a bit of carbon on them. The heads are both brand new, purchased 2 months ago. I used fel-pro gaskets all around, mahle bolt sets and torqued to spec.
I tested the rad pressure this morning. It holds pressure and does not loose any.
AUHUNTER78
Post Options Post Options   Thanks (0) Thanks(0)   Quote AuHunter78 Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2023 at 12:19PM
On another note. When checking the dip stick  I see that it is a white substance mixed with oil (not brown), I clean it and re check the oil, the dip stick has clean oil on it. No evidence of water contamination. But after I go out driving and re check, the white is back again. The oil level on the dip stick is at safe level. My oil pressure is always at normal (60) on the gauge.
AUHUNTER78
This page was generated in 0.146 seconds.
