  New Posts New Posts RSS Feed - Core support
Core support
Gold73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gold73 Quote  Post ReplyReply Direct Link To This Post Topic: Core support
    Posted: 04-March-2022 at 3:30AM
Quick question. Are the front core supports on a 72 and 73 Torino’s interchangeable?
Compton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2022 at 6:50AM
Yes they’re basically identical except for the location of the mounting nuts for the latch bracket…
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2022 at 8:35AM
the latches are different but i've never heard that the bolt locations changed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2022 at 9:34AM
The 72 has the latch bracket bolted to the front of the core support…73 on top and has welded in captive nuts…72 just has holes in the front…other than that they’re identical…
72
73
Was planning on putting the 73 latch into the 72 front that’s going on the car but not sure it’s worth the effort
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2022 at 12:18PM
i tried fitting a 73 hood to my 72, the latch didn't jive.
you may need to keep the hood and latch system all one year
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2022 at 12:37PM
Yeah that’s what I’ve been thinking….not the end of the world popping the bonnet from outside the car
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2022 at 2:10PM
Try retrofitting the hood latch parts from a late Crown Vic. I have a 95 that gave me the idea. The parts look like they are made to bolt on, the CV hoods are aluminum. So unless something is more difficult, it looks like with a simple large hole for the hood part to bolt on with two bolts, it should attach easily to any hood with a nice flat area there at the front center.
I have a 72 front also and plan to use the 73 latch cable etc. That under bumper hook has to go, I will fill that huge hole in the bumper to make it stronger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gold73 Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2022 at 4:17PM
Thanks for the info guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gold73 Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2022 at 4:18PM
This page was generated in 0.095 seconds.
