  New Posts New Posts RSS Feed - Dash
Dash
mcclainshane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcclainshane Quote  Post ReplyReply Direct Link To This Post Topic: Dash
    Posted: 13-November-2019 at 4:43PM
Are 1972 ford dashes interchangeable? I like the look of the 72 mustang dash.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 13-November-2019 at 6:08PM
If you are asking if a '72 mustang dash will fit into a '72 torino, the answer is no, it is not a direct replacement part. The '72 torino is four and a half to five inches wider from the drivers side across to the passenger side than the '72 mustang.
Edited by dave302 - 13-November-2019 at 8:10PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 13-November-2019 at 6:14PM
And then you will have to widen the mustang dash four and a half to 5 inches across from drivers side to passenger side to make it fit correctly. And then you will have to make all of the heater, defrost, ventilation and air conditioning parts fit, such as the duct work, vacuum diaphragm's, and controls. And the connectors for some of the wiring might be different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 13-November-2019 at 6:20PM
And then you will have to try to fit the torino accessories, gages and warning lights into the mustang dash. It will be a big project, and while some custom car shops and home mechanics have done this type of work before, it might not be worth it to some other people to spend weeks or months of time on a project like this one.
Edited by dave302 - 13-November-2019 at 8:09PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcclainshane Quote  Post ReplyReply Direct Link To This Post Posted: 14-November-2019 at 6:54AM
Ok I appreciate it. I liked the look of the mustang dash bezel and the center piece that comes down to the floor over the tunnel. Looked like it would fit a touch screen radio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 14-November-2019 at 7:02AM
Your welcome
This page was generated in 0.072 seconds.
