Dial Indicator |
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5325 |
![]() ![]() ![]() ![]() ![]() Posted: 02-December-2022 at 6:50AM |
I am looking at getting a dial indicator, with a base. Just looking for something for general automotive use, like setting up rear ends, checking valve lift, etc. I see a few options at Summit. The summit brand one looks okay, but some complaints of a weak magnet. The Chicago brand one looks decent too, but is a lot more money. |
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2348 |
I have a magnetic base and a dial indicator that have worked great since I got them in the early 90's, from Harbor Freight. The generic brands should do fine for most tasks, I would only worry about the accuracy of a caliper for serious work like engine bearing clearances etc. The magnet of my off brand base is very strong, when the lever is turned to engage it, you cannot easily remove it from the metal surface. I checked lifter preload with mine, as well as some valve lifts etc, and ring gear backlash 3-4 times. Mine were about $20 each about 30 years ago.
Eliteman76 ![]() Admin Group ![]() Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 4853 |
My question is, what level of quality would you use for dialing in Bell house runout?
I am pulling my tremec out soon for a re-fresh and need to consider spending time to make sure it's dialed in. Seems the Tremec 5 speeds are not like the Toploaders of olden days.
Camojoe ![]() New Member ![]() Joined: 11-June-2011 Location: Byron,GA. Status: Offline Points: 23 |
If you don't mind used, search ebay for a Federal brand indicator. I've been in machine work for more than 40 years, and have used various indicator brands over the years,and have several in my home tool box. In my opinion, Federal will make all other brands run up a tree. Starrett and Mitutoyo are both fantastic indicators, but don't have the smoothness and feel of Federal. You can find Federals in any resolution, such as one tenth of a thou (.0001"), which would be a little overkill for setting up ring and pinion backlash. Probably more than info than you asked for, but there it is. Regards, Duck
Edited by Camojoe - 14-March-2023 at 2:18PM |
werd tuh yuh momma and dim....
Greg73Oregon ![]() Senior Member ![]() Joined: 23-February-2021 Location: Roseville, CA Status: Offline Points: 212 |
Yes. The Harbor freight one is good. Used it to rebuild an engine. Measurement results were always repeatable. Magnet was fairly strong.
GKF
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14484 |
i dont recall the brand i have seams to me its central presision??? (no its not HF i got this way before HF was thought of) i do have the HF dial indicator and snap gauges. a few starrett mics, and a mitutoyo digital caliper...
Thanks CamoJoe, great advice!
