did 72 gts have a clutch safety switch? |
Post Reply
| Author | |
bigblocktisdale
Joined: 26-September-2010 Location: wisconsin Status: Offline Points: 99 |
Quote Reply
Topic: did 72 gts have a clutch safety switch?Posted: 11-September-2011 at 3:06AM |
I got some clutch pedals out of a 72 gts and it has a switch with a chain that goes from the clutch pedal to the fire wall then to the brake pedal. I was wondering if it is factory or not.
thank you Steve |
1972 Gran Torino Sport : 10.30 @ 131 mph NA
1991 mustang : 11.38 @ 123 mph sold 91 and bought a 67 mustang |
lynchster
Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2150 |
Quote Reply
Posted: 11-September-2011 at 6:12AM |
I'd have to look at my set up again but I don't recall that set up under my dash.
Eliteman76
Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 5450 |
Quote Reply
Posted: 14-September-2011 at 4:15PM |
Only switch on on a clutch pedal set would be for the brake light switch for the brake pedal.
No "chain" only would have the metal clutch rod that connects to the Z bar on the frame/trans bell house.
Andrew:GTS.ORG admin, '72 Q code 5 speed RestomodPondering: #99Problems |
Eliteman76
Quote Reply
Posted: 14-September-2011 at 4:18PM |
CLOSER SHOT:
bigblocktisdale
Quote Reply
Posted: 15-September-2011 at 2:05AM |
thanks eliteman thats what I thought. but I had to ask. it looks like some one added it on, I will try to get some pics of it and post them.
Eliteman76
Quote Reply
Posted: 15-September-2011 at 5:14AM |
I am thinking of one possibility. I know certain clutches, with this pedal set, you could have the clutch pedal slam to the floor.
Think it was guys having issues with Centerforce diaphram type clutches.
Maybe someone was having this issue and decided to fix it white trash style?
75GranMan
Joined: 05-April-2011 Location: Colchester, CT Status: Offline Points: 1225 |
Quote Reply
Posted: 15-September-2011 at 2:00PM |
do you know if the car the pedals came from had dealer add on speed control?may be a disconnect for the cruise? IE.clutch pedal movement activating brake lamp circuit to disable it? |
Eliteman76
Quote Reply
Posted: 16-September-2011 at 6:09AM |
I'm not aware of any 4 speed cars having CC on them.
The cruise cut off is based off the brake light switch.
See, Now I am curious what the hell that chain is on there for...
stanman
Joined: 23-March-2007 Location: Nova Scotia, Ca Status: Offline Points: 1434 |
Quote Reply
Posted: 16-September-2011 at 12:04PM |
There have been do-it-yourself cruise systems available for many years. That could explain the chain......or not.
bigblocktisdale
Quote Reply
Posted: 18-September-2011 at 10:43AM |
I could see it being after market cruise control. that would explain the way the switch was clamped to the clutch pedal and chained to the brake pedal.
thanks guys |
Post Reply
| Tweet |
