Differences in 5.0, 5.8, Modular Engine Dimensions |
unlovedford
Posted: 19-June-2015 at 4:35AM |
Ever wonder about the size differences between Ford small block 302/351 and the 4.6L modular engines?
302 (5.0L) 27-1/2 Inches L 20-3/4 Inches H 18-3/4 Inches W 351W (5.8L) 27-1/2 Inches L 23-3/4 Inches H 21 Inches W 4.6L SOHC 28 Inches L 26 Inches H 28-5/8 Inches W 4.6L DOHC 28 Inches L 29-7/8 Inches H 30 Inches W Edited by unlovedford - 19-June-2015 at 4:55AM |
dave302
In the diagram below, the DOHC modular motors are quite large and have a low output per cubic foot of space. The upper intake plenium is not shown for the modular motor (the black lined motor). It is wide and tall, but it is a bit shorter than the others when they are used in factory configuration. The 351's can be shortened a bit with careful cover/pump selection.
Edited by dave302 - 19-June-2015 at 7:30AM |
joe, are you wondering if the newer motor will work in your wagon? if a 460 will fit in there, i think you can make the newer motor fit ok, as with any engine swap, i'd say the main issues will be the pan configuration and exhaust issues mostly
unlovedford
Nah, I am forgoing any modular Torino drivetrain until I can get a Coyote setup. The price on salvage Coyote Mustangs is coming slowly down to Joe area prices - just have to be ready to pull the trigger on one once I get a suitable candidate (on both sides).
ok. i'm not up on this newer stuff so what exactly is a coyote motor? the only coyote i remember was a car from the t.v. show hardcastle & mccormick
Edited by californiajohnny - 19-June-2015 at 8:56AM |
unlovedford
The Coyote engines came out a few years ago in Mustang GT's as a 5.0. 412 horses from the factory, with EASY ways to extract huge gains in power. 750 HP out of a Coyote with a supercharger is only a call away.
Now, the 2015 factory versions start with 435 horses out of the 5.0. A neighbor has installed a Borla cat-back, CAI, a chip, a tune, and a couple of small trinkets on his 2015 and is getting nearly 500 horses - without cracking the engine open. It sounds scary fast and is. |
gotcha! yeah you can get tons of stuff for the newer mustangs, it's crazy!
unlovedford
Here are the official numbers, straight from Ford, pending certification.
For this sixth generation, the base 3.7-liter V6 model's power rating drops from 305 hp to 300 hp. Torque holds steady at 280 lb-ft. Compression ratio for the V6 is 10.5:1. The base V6 fastback with a manual weighs in at 3526 lbs, an increase of 30 lbs over the 2014 model. The GT, which uses a rowdier version of the 5.0-liter Coyote V8, now has 435 hp and 400 lb-ft of twist, up 15 hp and 10 lb-ft from its predecessor. The compression ratio is 11:1. In EcoBoost guise, the 2015 Mustang offers 310 hp and 320 lb-ft of torque from its 2.3-liter turbocharged four-cylinder on 93-octane gasoline. It's a twin-scroll turbo—the first ever used on a Ford. The compression ratio on the turbo 'Stang is 10.5:1. |
