Dip Stick location & Overheating |
Post Reply
| Author | |
79Cougar302
Joined: 05-February-2007 Status: Offline Points: 10 |
Quote Reply
Topic: Dip Stick location & OverheatingPosted: 05-February-2007 at 4:58AM |
got a 79 Cougar with 302.
It is overheating after about 5 miles....I checked the radiator-- I got good flow.....it maybe low on oil......can't check it ......
Where is the engine oil dip stick location??????
I looked all over---I think it is possible missing.............. ....plus little water coming out of the muffler.......it could be a head gasket problem?????? Will that cause the over heating????
Thanks y!!!! |
starsky76
Joined: 28-March-2008 Location: vegas Status: Offline Points: 1385 |
Quote Reply
Posted: 31-March-2008 at 4:16PM |
dipstick is in right front of timing cover.If it broke off someone may have plugged the cover hole.Is thermostat working?Timing off will cause it to overheat,severely retarded or advanced.A little water out of muffler is ok,condensation,moisture,as long as its not greenish or smells funny.do a coolant pressure test if you can.
Post Reply
| Tweet |
