  New Posts New Posts RSS Feed - Dip Stick location & Overheating
79Cougar302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Cougar302 Quote  Post ReplyReply Direct Link To This Post Topic: Dip Stick location & Overheating
    Posted: 05-February-2007 at 4:58AM
got a 79 Cougar with 302.
It is  overheating after about 5 miles....I checked the radiator-- I got good flow.....it maybe low on oil......can't check it ......
Where is the engine oil dip stick location??????
I looked all over---I think it is possible missing..............
....plus little water coming out of the muffler.......it could be a head gasket problem??????  Will that cause the over heating????
Thanks y!!!!
starsky76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote starsky76 Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2008 at 4:16PM
dipstick is in right front of timing cover.If it broke off someone may have plugged the cover hole.Is thermostat working?Timing off will cause it to overheat,severely retarded or advanced.A little water out of muffler is ok,condensation,moisture,as long as its not greenish or smells funny.do a coolant pressure test if you can.
This page was generated in 0.100 seconds.
