  New Posts New Posts RSS Feed - Disc brakes rear. Will crown vic master cyl work?
tonym9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonym9 Quote  Post ReplyReply Direct Link To This Post Topic: Disc brakes rear. Will crown vic master cyl work?
    Posted: 14-July-2023 at 5:28AM
Doing the rear disc conversion.
Does a crown vic master and proo valve work?
72 GTSFB
Post Options Post Options   Thanks (1) Thanks(1)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2023 at 9:52AM
Not sure what year CV you are referring to, but it would probably be better to use a MC from a 4 wheel disc '75 or '76 Thunderbird(it fits your original booster's bolt pattern-bolt-on application-no mods other than brake line fitting size differences) and use an aftermarket disc/disc proportioning valve(you will still need to change fitting sizes but the aftermarket unit uses double flare-the I believe CV prop valve uses a metric/bubble flare). When I went 4 wheel disc, I also installed hydroboost at the same time and used an '80 Corvette disc/disc MC due to fender side exit ports and matched it with an aftermarket disc/disc proportioning valve. Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonym9 Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2023 at 2:39PM
Great info. Thanks AQL
72 GTSFB
This page was generated in 0.084 seconds.
