Distributor top terminals |
Post Reply | Page 12> |
Eliteman76
Posted: 13-February-2015 at 2:16AM |
Guys anyone know if a small cap with male terminals for a duraspark dizzy 1976 model year?
I need to replace spark plug wires and I'm finding the ford racing plug wires are for a male terminal not a female. Also has anyone used a late model coil with a duraspark in our cars? I read a few places the late model 5.0/5.8 coil packs more punch over the older canister type. Can't imagine it's hard to swap. |
Pondering: #99Problems |
mcford
on the cap, there is not. everything uses that cap adapt and the large cap.
Eliteman76
Insert whiny rant *REALLY??!*
I was afraid of that. Any suggestions for a decent set of wires for the street? |
dave302
Summit Racing makes a set of wires that will fit your engine. They are available in blue and are spiral wound, just like the ford racing wires are. They have 45 degree grey spark plug boots and black distributor boots.
These 8mm wires feature high-temperature silicone outer jackets and insulation, along with a fiberglass braid for more pull strength. These wires are available in custom-fit or universal sets. The custom-fit sets have both terminal ends installed, while the universal sets have the spark plug boots installed and come with the distributor boot terminals and a stripping tool. They advertise that this "custom fit" wire set will fit the 1972 ford 400 Modified engines and other Ford, G.M. and A.M.C. V8 Engines. To see them for sale Click here.
Edited by dave302 - 17-February-2015 at 1:57AM |
dave302
Moroso also makes a set of Blue Max custom fit wires for your engine. They have Straight blue spark plug boots and black distributor boots.
Moroso's 8mm Blue Max Spiral Core ignition wire sets have a special strategically-wound 304 stainless steel conductor and Kevlar core that reduces the ohms of resistance per foot, while delivering more spark energy, better EMI suppression, and a higher dielectric strength. A tough 8mm synthetic silicone jacket resists high temperatures and oils, and the extra-thick EPDM layer adds greater electrical insulation. Compact silicone plug boots provide extra header clearance and feature fold-over crimped terminals for a secure connection. To see them for sale Click here. Edited by dave302 - 13-February-2015 at 11:31AM |
75GranMan
Andy,
I would custom build what you want. I'm not sue you'd be happy with the angle boots for your Cleveland.I have MSD wires for the male terminal cap. the wires are far to long, so I purchased the dist cap side kit, consists of 9 terminal and boots $13.50. I also ordered the crimper MSD 35051 $64 on ebay, comes with dies for crimping the terminal and you can purchase extra dies for multiple wire terminal styles. or you can buy their $8 vise style crimper. Buy the wires you like and custom tailor the dist ends. Nothing like custom wires, IMO.
i always custom make all my wires, because the sets you buy the wires come in two sizes--too long and way too long! i prefer mallory 8mm copper core, but they are getting less and less choices of color, so i usually go with accel. i wanted red for the torino so i had to go with a spiral core.
people say the copper core wires will static the radio, but i use resister plugs and never had any static! |
dave302
To see "Universal Fit" sets of spark plug wires with straight spark plug boots that will fit onto your engine Click here.
If you want to see more "Custom Fit" spark plug wire sets with straight/180 degree boots, for your engine/combination Click here.
Edited by dave302 - 14-February-2015 at 5:48AM |
bata747-8
Moderator Group Honorary Spam Bot / Zombie Account Joined: 24-June-2010 Location: China Status: Offline Points: 131 |
For my Mallory Unilite I was able to buy a male terminal cap conversion and get male to male wires which is so much better. No guessing if the wire in the cap is fully seated.
Forum Test Account
(formerly a spam bot account) |
yeah the old school female socket terminal caps can be questionable whether or not the wire is fully down & seated, I usually tweek the prongs of the wire terminal to add a small bit of spring into them and slide the weather boot up on the wire before attempting to plug 'er in
the extra spring should give you a feel of the nubs seating in the cap terminal, then slide the boot back down onto the cap tower while holding the wire in place downward who's to say the boot is in the correct location from a 3rd world sister slamming boots onto wires all day & shovin'em into a box? darn right the male tower caps are easier to assemble wires onto we didn't have all this new fangled stuff when I grew up! |
Eliteman76
John-
I thought about building my wires but I sort of shrug at the idea.With how picky I can be, you figure I would be making my own wires. Good tips thought!! I ended up getting the cap Rock posted up, along with a set of the Ford racing 9mm wires.
I also ordered a set of Ford OEM motorcraft wires for my F series which are basically the same configuration. I looked at pictures and frankly I am going to give the 45 degree boots a shot. Also ordered a new batch of good old #25 autolite plugs. Have not changed plugs on the GTS for a few years and figure Rock auto had them for $0.81 per plug. I was just going to pop for the moroso blue max wires again but I hate how they tend to look even with cable clamps. Worse case if the motor sport wires don't work, I'll order up the moroso wires. Thanks guys. I appreciate the help. |
72 RS 351
I have the Moroso Blue Max wires in a box someplace, if they may be what you end up wanting. I'm not positive I didn't ever use the coil wire, but it's new from the 80's otherwise.
dave302
Psquare75
Autozone 1600 or 1601 is a universal cut to fit wire set for $18. I did my F100 with Cougar with them. No issues years later.
unlovedford
^^Lifetime warranty as well.
mcford
yeah that cap is somewhat of an oddball, originally spec'd for AMC IIRC
go figure
Eliteman76
Got mine. Brass terminals. Looks decent for a cap. Made in Mexico.
Rockauto had these in stock. |
it works & clips on & everything?
Eliteman76
Had to file out the notch area for the duraspark distributor, mine has the casting for the advance diaphragm deal, just like how the regular duraspark cap goes on.
Note: 45 degree boots for a windsor don't fit worth a darn. I love these 9mm Ford Racing wires. Just needs straight boots and a few slight adjustments. Going to have to return them back to Summit Racing however. I'm beginning to think I need to man up buy plug wires that are trim to length. Always seems like #4 and #8 are an extra mile longer than they need to be. #5 plug wire ripped the damn metal plug deal out of the boot. Not happy about that. |
Eliteman76
Now that I'm awake and it's not 220am in the garage, as we are on this topic, what tools work best for assembly of wires?
Part#'s, manufacturers etc |
75GranMan
Andy, this is the MSD crimper that I purchased. I paid $64.00 on ebay.I have not assembled my wires yet, but from my research, these are the one to get. |
mcford
WELL WORTH IT. That 2 piece accel tool is a pos and a pita to use. if only one or two wires are too long, cut the end and shorten them. that's what i have done with a few premade sets. i bought a package of Accel wire ends just for doing this.
Eliteman76
OK kids, as stated before yeah. 351W wires don't fit for a darn on a Cleveland. I truly need to listen better to you guys.
So I still need a set of wires. I thought about buying a tool and 8 straight boots and just modifying these nice 9MM Ford Motorsport wires... And yes I agree the goofy odd length wires are bugging me. Just need the wire boos and terminals now...
dave302
Accel makes a kit for their 8.8 mm wires. But they are a red/orange color.
To see them for sale Click here. Moroso makes a kit with blue colored boots, but they are for their 8mm wires, so they will probably be a tight fit with your wires. To see them for sale Click here. Moroso also makes a kit for their 8.65mm wires, but they are a gray color. To see them for sale Click here.
dave302
To see another kit Click here. To see another kit Click here. These next two boot kits are advertised as being for a Male/HEI distributor. I have seen distributor boots being advertised with that description, but these are advertised as (and appear to be) spark plug boots. You might want to contact the seller for more information about that description. To see them Click here. Edited by dave302 - 24-May-2015 at 10:36PM |
dave302
To see the other kit Click here.
Eliteman76
Thanks I appreciate the info!!
dave302
Your welcome.
This next kit has blue boots, but they were designed to fit onto 8mm wires. So they might be a tight fit onto your wires. To see them for sale Click here.
