  New Posts New Posts RSS Feed - Dome Volume
Dome Volume
aaron74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aaron74 Quote  Post ReplyReply Direct Link To This Post Topic: Dome Volume
    Posted: 05-September-2013 at 10:00AM
I got a 74 gran torino and I'm trying to figure out what the compression will work out to be with aftermarket heads but I have no idea what the dome volume is or what the compressed gasket thickness would be. Any help?
robot9000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robot9000 Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2013 at 4:56PM
Summit will have the gasket thickness listed.  The head manufacturer should list the chamber volume in cc's.
Isn't dome volume for the pistons?  I could be wrong.
Here is the summit calculator that should get you what you need.
http://www.summitracing.com/expertadviceandnews/calcsandtools/compression-calculator
2010 Mazda 6
2007 Jeep Wrangler
2011 Damon Daybreak 35BD
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2013 at 5:10PM
what engine? 1974 pistons will be dished, and you'll also need the chamber volume
Post Options Post Options   Thanks (0) Thanks(0)   Quote aaron74 Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2013 at 12:30PM
Alright thanks, I have the chamber volume already just missing the dish
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2013 at 12:33AM
we still need to know what engine this is before anyone can help you out...
if it's a 351C with dished pistons you're looking at 8cc's
if it's a 400 with dished pistons your looking at 16cc's
I don't have numbers handy for 302 or 351W
Post Options Post Options   Thanks (0) Thanks(0)   Quote aaron74 Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2013 at 10:45AM
351 W
