  New Posts New Posts RSS Feed - Door Hinges - switch to ones with door stops
torinomike650 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinomike650 Quote  Post ReplyReply Direct Link To This Post Topic: Door Hinges - switch to ones with door stops
    Posted: 14-May-2019 at 2:35PM
See below pics of two hinges. The brown is my car, the green is Dave's.
The hinges on my car do not have that small door stop mounted, so the doors will sway shut if not manually held open. Does anyone know if I can switch over to these hinges with stops and have no problems mounting them?
Additionally, if changing my hinges would work, is there a source online where I can find this other type of hinge? I would also be interested if anyone has these available in good condition.
Willing to do what it takes to make the switch seeing as how these doors are ridiculously heavy and I do not want to risk the danger of them closing on someone unexpectedly.
1974 Ford Gran Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2019 at 5:09PM
the ones in the top pic are the bottom hinges
 ones like the other pic if i'm seeing it correctly are the top hinges
 are the "S" springs broken and missing???(common problem)
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2019 at 5:13PM
looking closer at the bottom pic...WTF? looks like someone used 2 top hinges!!??? i should have some decent hinges...
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinomike650 Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2019 at 5:44PM
Hey Johnny,
Yeah wasn't sure which hinges were in the pic.
On mine, the top and bottom hinges look nearly identical. Neither one looks like the one on Dave's car.
-Mike
mean steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mean steve Quote  Post ReplyReply Direct Link To This Post Posted: 15-May-2019 at 3:46AM
Yes you can change the bottom hinges to ones with detent setup. Not sure if available new but getting a set shouldn't be hard.
This page was generated in 0.092 seconds.
