Drilling and Installing New Seat Belt Bolts? |
r9b2 ![]() Member ![]() Joined: 16-June-2021 Location: Maine Status: Offline Points: 49 |
![]() ![]() ![]() ![]() ![]() Posted: 04-February-2022 at 3:53AM |
Hi all, I'm currently restoring my Torino, and a part of that involved removing both sides of the floorpans. As a consequence of that, the transmission tunnel was cut into and I no longer have the spot where the seat belt bolts were located. I do plan on re-installing brand new seat belts (my 1973 Torino has the shoulder belts up top, so it should be very simple to install), but my question is this: Would it be okay to take a 1/4" thick or so square sheet of steel, weld it to the original bolt locations, re-drilling and putting new bolts in place? Thanks in advance.
1973 Ford F100 429 1966 Ford Mustang I6 2017 Ford Expedition |
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14484 |
a drivers license size piece of 1/4" wound be sufficient to spread the load for the belt attachment points. i'd weld it to the pan or rocker
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2348 |
I really like the T50 seat belt bolts, but when they seize up and don't come out, they are hell to remove. I've only had one not come out, and a couple or three that I barely got out. Anti-seize is the key to helping them survive, but you have to remove them for some reason first.
