  New Posts New Posts RSS Feed - Drilling and Installing New Seat Belt Bolts?
r9b2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote r9b2 Quote  Post ReplyReply Direct Link To This Post Topic: Drilling and Installing New Seat Belt Bolts?
    Posted: 04-February-2022 at 3:53AM
Hi all,
I'm currently restoring my Torino, and a part of that involved removing both sides of the floorpans.  As a consequence of that, the transmission tunnel was cut into and I no longer have the spot where the seat belt bolts were located.  I do plan on re-installing brand new seat belts (my 1973 Torino has the shoulder belts up top, so it should be very simple to install), but my question is this:
Would it be okay to take a 1/4" thick or so square sheet of steel, weld it to the original bolt locations, re-drilling and putting new bolts in place?
Thanks in advance.
1973 Ford F100 429
1966 Ford Mustang I6
2017 Ford Expedition
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-February-2022 at 10:19AM
a drivers license size piece of 1/4" wound be sufficient to spread the load for the belt attachment points. i'd weld it to the pan or rockerWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 04-February-2022 at 12:27PM
I really like the T50 seat belt bolts, but when they seize up and don't come out, they are hell to remove. I've only had one not come out, and a couple or three that I barely got out. Anti-seize is the key to helping them survive, but you have to remove them for some reason first.
