  New Posts New Posts RSS Feed - Engine install bolts???
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Topic: Engine install bolts???
    Posted: 04-July-2013 at 8:35PM
Ok guys another question.
Since this is not a replacement engine but rather an upgrade from a 351W/c-4, I do not have bolts for engine to bellhousing and also the flywheel bolts that mount to crankshaft. I notice arp has the flywheel bolts but not the engine to bellhousing bolts which are just a basic 7/16-14 at 1 1/4 inches in length.
What did you use for both sets of bolts in your car?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2013 at 2:30AM
bring 'us'(me) up to speed again what's going in place of the W/C4 ?
likely the same flex to crank bolts will work for any motor to a C6 ?
I used local hardware grade 8 bolts(overkill) to snug up my C6 bell. not factory appearing with the gold iridite plating but I suppose a little black paint would help... or, i'll bet someone here has a stash of factory bolts that'll fit into a std rate box
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2013 at 4:20AM
I would definately use the ARP bolts for the flywheel to crank.
If the torque converter is bolts and not studs with nuts... Grade 8 all the way
Same for the bell housing... a set of Grade 8 and forget about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2013 at 5:44AM
Great advice ^^^. Stock 460's (at least all the 429-460s I disassembled) came with a "reinforcing" ring that goes onto the flexplate after you place it onto the crankshaft flange, it spreads out the flexplate/flywheel attachment bolt torque to avoid cracking or metal fatigue of the flexplate. I would recommend using it if possible. Todd
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2013 at 5:55AM
I think I have some bell bolts from when I did the TKO in my F100.
Robbdtme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2013 at 7:13AM
I would check on the flywheel aren't 351's externally balanced at 28oz on each end or is that just front harmonic balancer?
Edited by Robbdtme - 05-July-2013 at 7:15AM
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2013 at 8:57AM
The 351w is sitting outside still. But I do like the idea of getting the arp bolts for the flywheel, new bolts with a high torque engine is always a good thing. New converter came with nuts on it already. I will get some grade eights if needed but was hoping to find some black oxide or something slightly better quality. I can't believe of all the bolts arp makes that they don't have those.
There is an outfit I saw mentioned on 460ford.com called Lem Evans or something. Might give them a call Monday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2013 at 3:56PM
Scott, if the converter has STUDS on it then regular lock nuts(Grade 8) will work. The studs are what takes the power. no worries
This page was generated in 0.093 seconds.
