  New Posts New Posts RSS Feed - Exhaust Manifold bolts
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust Manifold bolts
    Posted: 06-January-2011 at 5:46AM
So I have what is really a general (all engine type) question:
What type of exhaust manifold bolts should I use with standard exhaust manifolds?
This is specifically related to my 71 F-250 with the 360 FE in it.
When I had originally done a great deal of work to it, I replaced every bolt I could (the old ones were literally breaking of by the dozen, it was crazy) with a nice and shiny ARP accessory bolt mount kit in stainless steel.
Very, very nice bolts.
When I had the cracked exhaust manifold a year later (I did not change those bolts), when I bought a new manifold I opted to put in some ARP stainless bolts there as well (manifold to head).
A couple months go by and they loosened up. I get new gaskets, remove, replace and retorque and then I loctite the lower aft bolts that loosened up.
Fast forward several more months (to last week) and I am under the hood looking at my wonderful coolant-in-the-combustion-chamber issue, and notice an upper aft bolt is worked it's way out at least a quarter of an inch (not one that I had loc-tited).
What was there before were bolts from Lowe's or Home Depot, and while they were junk, they also did not loosen up.
Would I be better off getting the ARP black oxide bolts? Should I have loc-tited every bolt?
Should I go to Home Depot and buy some bolts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2011 at 5:50AM
Sadly I think on my exhaust manifold equipped cars, I just grab HD/Lowes bolts, and actually, I put Never Seize on them.. I always have trouble with those BREAKING, lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2011 at 6:54AM
I bought the header bolts from O'Rielly's.
When I do straight manifold work, I just use Grade 5 or 8 bolts from the hardware store. The thickest washers they have available and ALWAYS use Anti-Sieze on the threads... NEVER loc-tite!!
Never had a problem.
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 12-January-2011 at 5:03AM
on manifolds, i just go to the hardware store and buy stainless bolts and lock washers.  NEVER have had a problem with clevelands or 429/460's.
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 12-January-2011 at 12:15PM
Yea, I think I'm going to go with some Lowe's grade-8's.
ARP has header bolts that are drilled for safety wire. Since I know how to install safety wire from my previous aircraft maintenance days, I thought that would be perfect. The only problem was that they only came in lengths for headers (I need a bit longer for the manifolds).
Safety wired bolts would have been the way to go. A little messy, but effective.
stanman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanman Quote  Post ReplyReply Direct Link To This Post Posted: 12-January-2011 at 2:41PM
I've seen them use locking header bolts on the Powerblock shows on Spike, but I haven't looked into where they bought them. Probably pretty pricey, I'm a cheapskate.
This page was generated in 0.061 seconds.
