Exhaust Manifold bolts |
GranTorinoSport
Posted: 06-January-2011 at 5:46AM |
So I have what is really a general (all engine type) question:
What type of exhaust manifold bolts should I use with standard exhaust manifolds? This is specifically related to my 71 F-250 with the 360 FE in it. When I had originally done a great deal of work to it, I replaced every bolt I could (the old ones were literally breaking of by the dozen, it was crazy) with a nice and shiny ARP accessory bolt mount kit in stainless steel. Very, very nice bolts. When I had the cracked exhaust manifold a year later (I did not change those bolts), when I bought a new manifold I opted to put in some ARP stainless bolts there as well (manifold to head). A couple months go by and they loosened up. I get new gaskets, remove, replace and retorque and then I loctite the lower aft bolts that loosened up. Fast forward several more months (to last week) and I am under the hood looking at my wonderful coolant-in-the-combustion-chamber issue, and notice an upper aft bolt is worked it's way out at least a quarter of an inch (not one that I had loc-tited). What was there before were bolts from Lowe's or Home Depot, and while they were junk, they also did not loosen up. Would I be better off getting the ARP black oxide bolts? Should I have loc-tited every bolt? Should I go to Home Depot and buy some bolts? |
Webmaster |
Psquare75
Sadly I think on my exhaust manifold equipped cars, I just grab HD/Lowes bolts, and actually, I put Never Seize on them.. I always have trouble with those BREAKING, lol.
Regul8r
I bought the header bolts from O'Rielly's.
When I do straight manifold work, I just use Grade 5 or 8 bolts from the hardware store. The thickest washers they have available and ALWAYS use Anti-Sieze on the threads... NEVER loc-tite!!
Never had a problem.
mcford
on manifolds, i just go to the hardware store and buy stainless bolts and lock washers. NEVER have had a problem with clevelands or 429/460's.
GranTorinoSport
Yea, I think I'm going to go with some Lowe's grade-8's.
ARP has header bolts that are drilled for safety wire. Since I know how to install safety wire from my previous aircraft maintenance days, I thought that would be perfect. The only problem was that they only came in lengths for headers (I need a bit longer for the manifolds). Safety wired bolts would have been the way to go. A little messy, but effective. |
Webmaster |
stanman
I've seen them use locking header bolts on the Powerblock shows on Spike, but I haven't looked into where they bought them. Probably pretty pricey, I'm a cheapskate.
