Few Questions |
302ford ![]() Member ![]() Joined: 24-February-2008 Location: vancouver Status: Offline Points: 178 |
![]() ![]() ![]() ![]() ![]() Posted: 08-December-2008 at 6:17PM |
Hey, I have a 79' LTD II that I'm currently in the process of building. I'm Stabbing in a 408 stroker and tko 5 speed in it to replace my built 302 and c4. Just Curious if anyone has managed to chuck in a cable operated clutch setup or if I'm stuck going hydraulic?
Also, I like taking corners in this beast and am quite confident in the car. I currently have a fresh Saginaw box, all new steering parts, stiffer springs, QA1 ajustable shocks and poly bushings thoughout. The only problem I have is the body roll with my current setup of a small 1" front sway bar. I'm curious if there is anything bigger I can use than a 1 1/8 front, and 7/8 rear I see online.
Thanks in advance
Chad Edited by 302ford - 08-December-2008 at 6:20PM |
You could adapt a front bar to the rear if you wanted to tighten it up.
Thanks, I'll look into this. Is it more of a custom fab job or direct bolt in?
Custom. Weld some brackets to the rear axle, and to the frame. Fab up some endlinks.
I'm surprised at the body roll you have.. I run the big 1 1/8" bar and the addco 7/8" rear bar and it's damn near flat. Then again, I run 17" rims with 50 series tires. |
I'm sure the body roll would be greatly minimised if I just ran a 1 1/8 with a 7/8 but I just wanted to see what was out there before I thow down the money. I think I'll probably just grab a 1 1/8 now and chuck my current front bar on the rear. |
Eliteman76 ![]() Admin Group ![]() Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 4879 |
As far as the coils...what rate are you running.
I know personally from dealing with a few guys, these cars need all the spring you can get.
Talking 700-850 pound rate springs...but be forewarned too much, and you got yourself a dump truck ride.
Sway bars, you got it pretty much handled, front bar flip to bac works.
Book from a place called MRE has info on the fab to put a front bar out back, but it's pretty basic.
Have a good one
Andy
I still stand by my.
"big rims, small tires" poly bushings, big sway bars, small block springs (with a big block) and bilstein shocks. The car is between my Z24 and my Truck for handling. |
I'm running a 480lb springs out front currently with I believe 220's out back. I think I want to step it up a bit in the future though. The QA1 12 way ajustable shocks I have in now are absolutly amazing and would definatly recommend them. I can change my ride from a sloppy mess to a setting so stiff I dont even think my springs are even working.
Thanks for the info
Also quick question. I'm looking to buy new headers for the 408 setup and was curious if any one knows of a 1 3/4" or 1 7/8" primary that will fit these cars?
