Final Remnants - Torino / Ranchero |
newmexguy ![]() Member ![]() ![]() Joined: 27-September-2012 Location: las Cruces Status: Offline Points: 163 |
![]() ![]() ![]() ![]() ![]() Posted: 08-May-2022 at 6:47AM |
Final remnants - final pieces left from pick a parting over a decade ago
70-71 Crossmember, Very clean condition, desert piece, with two outer bolts $100 70-71 Headlight and related pieces. RH headlight buckets, with rings and bracket to mount to rad support. Clean $50 70-71 Lower trim pieces, believe go under headlights Clean $40 both, buy all headlight related pieces, $75 72-79 LR window regulator, should fit most coupes of that era $25 (3) Wide trim clips, believe from '73 Coupe $20 Ship Via US Mail CANADA is extra |
