  New Posts New Posts RSS Feed - Floor pan drain holes
smitty-1976 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty-1976 Quote  Post ReplyReply Direct Link To This Post Topic: Floor pan drain holes
    Posted: 10-November-2009 at 5:29AM
Has anyone had positive or negative experice plugging the floor pan drain holes? The only value I am hearing for the holes is in case of flooding you can drain the floor pan.  Since I have not flooded a car in..ever...then they can be closed up in my mind.  Any thoughts on if this should be done and if so how would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 15-November-2009 at 10:22AM
I think for the aggravation I'd put the plugs back, and forget they are there.
