FLOOR SHIFTER |
tjbooker ![]() Member ![]() Joined: 21-August-2005 Status: Offline Points: 76 |
![]() ![]() ![]() ![]() ![]() Posted: 09-August-2006 at 11:59AM |
HELP, DO ANY OF YOU GUYS KNOW,
IM CONVERTING MY 74 TORINO FROM COLUMN SHIFT TO FLOOR SHIFT,
I HAVE A SHIFTER AND THE FMX SHIFTER ROD. I READ SOMEWHERE THAT A SHIFTER ARM IS ALSO NEEDED BESIDES THE ROD AND SHIFTER BECAUSE THE
SHIFTER ARMS ARE DIFFERENT THAN ON COLUMN SHIFTERS. ANYONE KNOW?
THANKS TJ
Torinogts73c ![]() Senior Member ![]() ![]() Joined: 14-February-2004 Location: Tucson Arizona Status: Offline Points: 1029 |
Yes you need to change the shift lever on the trans. as well as it is opposite of the column shifter. Gary
"Never complain Never explain" |
GranTorinoSport ![]() Admin Group ![]() ![]() Admin of "The Org" Joined: 20-May-2003 Location: Seattle Status: Offline Points: 2278 |
Does anyone know where to get the C-6 version of the shift lever in the transmission? All I have ever found was the C-4 version...
Webmaster |
Question:
Where do you cut the hole for the floor shifter?
I have the floor pan exposed and it is not obvious at all there it goes...
Webmaster |
