Flywheel and 11" clutch kits for 72-74 CJ |
Eliteman76 ![]() Admin Group ![]() Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 4806 |
![]() ![]() ![]() ![]() ![]() Posted: 21-September-2022 at 3:54PM |
So after reading on questions on flywheels, and looking for a flywheel for Bruiser, a few things come to mind.
First: Rockauto is not listing the correct clutch flywheel kits anymore for the 72-74 four speed cars. Data shows a 10.5" wheich is not correct. AMS used to supply 11" kits and they are no longer listed on Rockauto. I don't ever recall the torinos using anything but an 11" clutch kit. Now all the sudden the listings have updated for the correct 11" kits? https://www.rockauto.com/en/catalog/ford,1972,gran+torino,5.8l+351cid+v8,1129003,transmission-manual,clutch+kit,1993 Note, this is for the 351 Cleveland Q code which I am searching. For all I know they are referencing the H code 351C 2v or 351W 2V. I posted this on another recent post specifically looking into flywheels matching my original data off my casting: My original Ford flywheel that I am still using has this cast and stamped on it: Cast# C5AE 6380-E Stamped# C7TE-A I looked on pioneer and had to look under 1970 Mustang 351 (Doesn't say C or W) and got back: PART NUMBER : FW-193 Original Equipment (OE) Part InterchangeOEM: C5AZ-6375K Rockauto generally has been a solid catalog reference, however they only list for a 10" clutch. Assuming this is for 6 cylinders or is an error on their part. 28.2 OZ. Imbalance Flywheel -157 Tooth; For 10" Clutch Now, with that said, would something basic like say 1988 Ford Bronco 5.8 / 351W flywheel also be an OK choice? https://www.rockauto.com/en/catalog/ford,1988,bronco,5.8l+351cid+v8,1105928,transmission-manual,flywheel,5348 I use that for a reference as I am using a 1988 Bronco 5 speed starter in place of the original Ford Starter that came off my Q code. I'm just looking at for practical purposes this flywheel: AMS AUTOMOTIVE 167735 At what point do you consider the need to go to SFI/Billet Steel for flywheels, is something I have wondered on a street car application? I've bangshifted the heck out of the GTS over the years, and I have also had the factory FoMoCo flywheel magnufluxed every time I service the transmission or clutch kit out of safety. |
Yellosn ![]() Member ![]() ![]() Joined: 14-February-2020 Location: Eugene, OR Status: Offline Points: 119 |
This is the clutch I put on mine last year. Nothing fancy, but it seemed to be a decent quality. Works well so far. Weird about the flywheel listings??🧐 ![]() |
Troy Emerson
Eugene, Oregon 1972 GTS 4speed |
lynchster ![]() Senior Member ![]() ![]() Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2126 |
If you're going to hammer it may as well go with a blow proof bell housing.
I haven't done any high rpm shifting yet but I went with a diaphragm clutch. It grabs nice. If it manages to pin the pedal to the floor I may need a block behind the pedal.
