FMX to C4 swap |
corder13 ![]() Member ![]() Joined: 29-June-2004 Location: United States Status: Offline Points: 15 |
![]() ![]() ![]() ![]() ![]() Posted: 12-March-2006 at 12:21AM |
I read somewhere on the Ford Transmission Forum that the crossmember for a C4 is different than the one for an FMX. Does anyone know for sure if that is correct for our cars? I already have a built C4 to go in the car, and the shop up the road will do it. However, I'd like to make sure that all the pieces they need will be there when they do it, so I can get it licensed immediately afterwards. Also, I read on the same forum that the driveline length was not a problem, so I'm guessing they're fairly similar in length as well? Rick |
Torinogts73c ![]() Senior Member ![]() ![]() Joined: 14-February-2004 Location: Tucson Arizona Status: Offline Points: 1029 |
The X-member is the same no matter what trans, however the trans mount is different for the C-4 so go to your auto supply and get one for a C-4. Gary
"Never complain Never explain" |
Gary, Thanks for the reply. Any idea if the trannies are actually the same length? Rick |
The C-4 uses a shorter a shorter drive shaft a believe about an inch. C-4 has 28 spline yoke FMX is 31 spline
Ok, thanks! Now all I need to do is find a yoke. My grandfather said he'd take care of the driveshaft for me.
![]() Rick |
