Ford 8inch Torque Specs |
roknxj ![]() Member ![]() Joined: 13-July-2018 Location: So. Cal Status: Offline Points: 97 |
![]() ![]() ![]() ![]() ![]() Posted: 30-July-2018 at 5:21AM |
Can anyone tell me what the torque specs are for a Ford 8 inch axle? From axle / wheel bearing bolts to the 3rd member. I have some specs but not all. Here is the work i have done so far.
Thanks,
Joe |
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5607 |
Give me a day and I should be able to get them for you
The differential bearing cap bolts are 55-70 ft-lbs for a 8" rear differential.
The differential bearing cap bolts are 70-85 ft-lbs for a 9" rear differential. All below specs are for 8" and 9" differentials. Differential bearing adjusting lock nut bolts: 12-25 ft-lbs Carrier to housing stud nuts: 25-40 ft-lbs Pinion retainer to carrier bolts: 30 -45 ft-lbs Ring gear attaching bolts (use Loctite): 70-85 ft lbs Oil Filler Plug: 25-50 ft-lbs Rear Axle Shaft Bearing Retainer bolt nuts: 20-40 ft-lbs (Torino, Montego, Comet, Maverick, Mustang and Cougar). Universal joint to Pinion Companion Flange Bolt Nuts (except civular flange): 12 -15 ft-lbs Circular Flange: 70-90 ft-lbs Edited by 72FordGTS - 31-July-2018 at 12:53PM |
