  New Posts New Posts RSS Feed - Ford Parts guys need help.
madmaxtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Topic: Ford Parts guys need help.
    Posted: 11-September-2014 at 3:57PM
Need to know what these brake valves fit. D5MY-2B257-A and D5MA-2B328-A2B
Allan
Revelation 6:8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2014 at 4:05PM
I posted on Facebook to Gary, he works for Ford.
Ramair351, Pete, also can help.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2014 at 12:44AM
The D5MY-2B257-A is for a 1975 mercury Marquis with rear disc brakes.  It is a ford and mercury pressuse differential valve. It is the same exact valve as the part number D6AZ-2B257-E .
Edited by dave302 - 12-September-2014 at 1:30AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2014 at 1:48AM
I cannot find any information at all on the D5MA-2B328-A2B part number. Maybe one of the other members will know.
But many times there is the service part number and the engineering part number. The service part number might be D5MY-2B257-A and the engineering part number might be D5MA-2B328-A2B?
Are these two different valves that you are asking about? Or are both of those part numbers printed on the same valve?
I have found an application for a D5MA-2B328-AB part number (notice that there is no number 2 in the part number). It is a combination proportioning valve and differential valve. It measures 6 inches long by 3 inches high, it is usually used for a drum brake to disc brake conversion on ford and mercury vehicles. The part number is from 1975.
Edited by dave302 - 12-September-2014 at 1:52AM
Torinogts73c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torinogts73c Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2014 at 3:51AM
THE D5MA-2B328-A2B is an engineering number for i.d. purposes it crosses over to the D5MY-2B257-A . which has been superceded by D6AZ-2B257-E YES it is for for rear discs and police apps.
Edited by Torinogts73c - 12-September-2014 at 3:54AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2014 at 1:56PM
Thanks for the answers! I bought one nos and wanted to confirm its application. gonna use it on my torino to change to 4 wheel disc. Seller has some more of these nos if anyone is interested. They are $ 175.
Allan
Revelation 6:8
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2014 at 2:06PM
Your Welcome.
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2014 at 4:17AM
What rear disc style are you intending to set up?
Webmaster
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2014 at 2:10PM
   79 lincoln
Allan
Revelation 6:8
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2014 at 3:23PM
   79 lincoln
Mark V, I presume?
Webmaster
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2014 at 3:44PM
yea
Allan
Revelation 6:8
Billy C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy C Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2014 at 8:45AM
I'm working at the 79 Lincoln Mark brake swap too. The biggest setback was the bolt pattern but I solved that by just going with different wheels. Luckily I had a donor car so pulling everything off was a breeze. I think I'll be pawning off all my 5 on 4.5 stuff one of these days.
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2014 at 9:01AM
If a person was good with 5x5 bolt pattern, is the rest pretty straight forward?
Webmaster
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy C Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2014 at 5:51PM
ya... mostly bolt on.  That proportioning valve shown above is going to be part of the swap too (if it is the same one). Lot more cool stuff with the swap, but that's for another post
I should check my Lincoln proportioning valve part numbers and see if they are the same...
Montego01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Montego01 Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2014 at 10:50PM
I bought that valve and found as mentioned the only difference is the size of the line for the rear brakes
Scott
72 Montego GT 429 build thread
1966 Chevy C10
1973 Montego MX
2004 Bonneville GXP
This page was generated in 0.092 seconds.
