  New Posts New Posts RSS Feed - Radio knob removal
Radio knob removal
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Topic: Radio knob removal
    Posted: 02-March-2015 at 1:37PM
I peaked at the radio today and I'm not sure how to remove the knobs. Anybody has a tip?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2015 at 2:01PM
i believe they just pull straight off, but the wiper and the heater control knobs have a little metal clip on the back that has to be held forward while sliding them off, the radio might be like that, but i don't think so.
 are you getting those rear belts out while you're removing the radio for him too??? Wink Big smile
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2015 at 2:41PM
Pull
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2015 at 2:56PM
This will undoubtedly/absolutely help with the radio knob removal process, guaranteed to remove ANY radio knob ever installed-REAL EZ. LOL
war blood crowbar mafia photomanipulation blooded wallpaper
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2015 at 3:00PM
After you remove the two knobs, there might be those two nuts that you will have to remove, in order for you to remove the radio from the vehicle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2015 at 3:07PM
Some of the things that i have seen people use to remove those nuts are:
1) 2 small screwdrivers placed on either sides of the shaft nut and turn, then once it is slightly loose, you hold the back of the radio while turning the nut with 1 screwdriver.
2) The Divot correction tool that the people who play golf use (looks like 2 prongs attached to a wide blade).
There is a picture below of a divot tool. To see one for sale Click here.
Edited by dave302 - 02-March-2015 at 3:52PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2015 at 3:08PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2015 at 3:15PM
I have also seen some people use needlenose pliers. They had used the ends like a spanner wrench and pushed out with the tips instead of squeezing to turn the nut.
They also make a special tool for those radio nuts. Its the same tool to remove power antennas. I have seen them at Matco tools and at napa. To see one for sale Click here.
Edited by dave302 - 02-March-2015 at 3:23PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2015 at 3:23PM
I have also seen some people unscrew the face plate and remove the radio and face plate in one piece. Once it's out, you can easily remove the round nuts by hand. There are two screws above the radio, and two in the ash tray below.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2015 at 3:37PM
You can also use a small flat head screwdriver and a hammer to loosen the radio knob nuts. Just tap the nut on the edge with the screwdriver and it should loosen up.
I had also seen someone make his own radio nut removal tool. There is a picture below.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 03-March-2015 at 2:47AM
I use needle nose pliers or two small screwdrivers. Jiggling the radio from behind will aid in removal of those nuts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 03-March-2015 at 7:43AM
This is the method I use, very easy, and no risk of stripping the nuts or damaging the dash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 03-March-2015 at 11:13AM
hey... thats mine!!  Clap
bdaugette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdaugette Quote  Post ReplyReply Direct Link To This Post Posted: 10-March-2015 at 6:19AM
Did you get the knobs off?!
Bill Daugette
72 GTS 351C 4V
This page was generated in 0.161 seconds.
