72 passenger door lock? |
| Author | |
russosborne
Joined: 01-January-2015 Location: Glendale AZ Status: Offline Points: 664 |
Topic: 72 passenger door lock?Posted: 06-May-2015 at 9:43AM |
On mine I cannot lock the passenger door with the key,it only works to unlock. Is this normal or do I have a lock issue?
Thanks, Russ |
Regul8r
Moderator Joined: 26-December-2007 Location: Sarasota FL Status: Offline Points: 6624 |
Posted: 06-May-2015 at 9:54AM |
spray some lube in to the lock and work it.
Might have to take the door panel off and check the linkage or spray it all as well. |
mcford
Joined: 31-May-2003 Location: Utica, Michigan Status: Offline Points: 2174 |
Posted: 07-May-2015 at 6:23AM |
DONT USE SPRAY LUBE. USE POWDERED GRAPHITE LUBRICANT. COMES IN A SMALL TUBE. SPRAY LUBE WILL EVENTUALLY COLLECT MORE DUST/DIRT AND YOU'LL HAVE THE SAME PROBLEM AGAIN.
Joined: 25-August-2013 Location: New York Status: Offline Points: 4195 |
Posted: 07-May-2015 at 10:34AM |
DO NOT use WD-40. As the locks wear, the anodizing on the aluminum wears away, and WD-40 will eat into the metal of the lock.
