  New Posts New Posts RSS Feed - LICENCE PLATE HOLDER
rab1969 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rab1969 Quote  Post ReplyReply Direct Link To This Post Topic: LICENCE PLATE HOLDER
    Posted: 17-July-2009 at 2:47AM
Does anyone have a 1972-1973 rear licence plate holder that is not broken for sale or does anyone know of any after market company that sells them and are there any aftermaket sheet metal out there.
72grantorinonut
Allen
picon3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote picon3 Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2009 at 4:42AM
Allen,
Try http://www.blueoval6079.com/ in Georgia.  They usually have everything.
Paul~
Edited by picon3 - 17-July-2009 at 5:53AM
1972 GTS 351CJ-4V black/black
Post Options Post Options   Thanks (0) Thanks(0)   Quote rab1969 Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2009 at 6:15AM
thanks paul
72grantorinonut
Allen
baough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baough Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2009 at 7:59AM
I discovered that the fuel filler door from a 75 Elite works perfect for my 73 G.T. All I had to do was remove the trimwork since it was shot anyways, and use the framework behind the trim. Just drilled a couple of new holes in the rear valance or cowl or what ever you want to call it since the bolt patern wasn't the same, and it's made out of steel instead of plastic. It looks like it belongs there.
Former U.S. Navy submariner onboard USS Sturgeon SSN 637
73 Gran Torino,351C,auto
76 F250 4x4, 390
88 comanche
91 explorer
92 bronco
08 Harley 883C, two kids, 4 horses,2 dogs,2 cats,1 lizzard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2009 at 8:24AM
If you have an original, get a stainless steel piano type hinge, and just drill a couple holes and pop rivit the fold down part to the base.
I've repaired mine after seeing a guy on Ford muscle explain it. Took me a half hour of screwing around and 5 minutes to drill 6 holes and pop rivit it together.
I have a couple spares floating around, one fixed, and I know I have a steel unit off an older Torino that is pretty much the same.
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2009 at 11:29AM
like andy says, piano hinge available at the local hardware store and fix it.  i fixed the one on my 72 4dr, need to do the one on the GTS but that one may be too busted up to save.
Edited by mcford - 18-July-2009 at 9:06AM
interceptor460 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote interceptor460 Quote  Post ReplyReply Direct Link To This Post Posted: 18-July-2009 at 4:12AM
I have one too in good shape .
This page was generated in 0.099 seconds.
