LICENCE PLATE HOLDER |
| Author | |
rab1969
Joined: 09-November-2008 Location: NC Status: Offline Points: 72 |
Topic: LICENCE PLATE HOLDERPosted: 17-July-2009 at 2:47AM |
Does anyone have a 1972-1973 rear licence plate holder that is not broken for sale or does anyone know of any after market company that sells them and are there any aftermaket sheet metal out there.
72grantorinonut
Allen |
picon3
Joined: 20-February-2007 Location: North Carolina Status: Offline Points: 2106 |
Posted: 17-July-2009 at 4:42AM |
Allen,
Try http://www.blueoval6079.com/ in Georgia. They usually have everything.
Paul~ Edited by picon3 - 17-July-2009 at 5:53AM |
1972 GTS 351CJ-4V black/black
rab1969
Posted: 17-July-2009 at 6:15AM |
thanks paul
72grantorinonut
Allen |
baough
Joined: 28-January-2008 Location: Graham, Wa. Status: Offline Points: 93 |
Posted: 17-July-2009 at 7:59AM |
I discovered that the fuel filler door from a 75 Elite works perfect for my 73 G.T. All I had to do was remove the trimwork since it was shot anyways, and use the framework behind the trim. Just drilled a couple of new holes in the rear valance or cowl or what ever you want to call it since the bolt patern wasn't the same, and it's made out of steel instead of plastic. It looks like it belongs there.
Former U.S. Navy submariner onboard USS Sturgeon SSN 637
73 Gran Torino,351C,auto 76 F250 4x4, 390 88 comanche 91 explorer 92 bronco 08 Harley 883C, two kids, 4 horses,2 dogs,2 cats,1 lizzard. |
Posted: 17-July-2009 at 8:24AM |
If you have an original, get a stainless steel piano type hinge, and just drill a couple holes and pop rivit the fold down part to the base.
I've repaired mine after seeing a guy on Ford muscle explain it. Took me a half hour of screwing around and 5 minutes to drill 6 holes and pop rivit it together.
I have a couple spares floating around, one fixed, and I know I have a steel unit off an older Torino that is pretty much the same.
mcford
Joined: 31-May-2003 Location: Utica, Michigan Status: Offline Points: 2174 |
Posted: 17-July-2009 at 11:29AM |
like andy says, piano hinge available at the local hardware store and fix it. i fixed the one on my 72 4dr, need to do the one on the GTS but that one may be too busted up to save.
Edited by mcford - 18-July-2009 at 9:06AM |
interceptor460
Joined: 24-February-2009 Location: montreal Status: Offline Points: 409 |
Posted: 18-July-2009 at 4:12AM |
I have one too in good shape .
