  New Posts New Posts RSS Feed - torque converter help fmx
slow72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slow72 Quote  Post ReplyReply Direct Link To This Post Topic: torque converter help fmx
    Posted: 14-December-2014 at 11:02PM
Im running a decent 351w in my 72 with stock hears and an fmx trans. The car will do great rolling burnouts but leaves the line like a pig. It seems like there aren't very many options for torque converters out there for that fmx. Has anyone had any luck?
Josh Mcclean
*72 formal roof torino
*73 ranchero 500
*55 Studebaker Chanpion
*70 Maverick 6cly
*88 F250 hd
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 15-December-2014 at 2:40PM
you won't find much / if anything at all listed in sale ads but a decent converter can be built by just about any outfit that isn't stuck in an assembly line mentality
could be your rear gear too, any idea what it is?
a 2.5 or 2.75 rear isn't gonna impress off the line
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 16-December-2014 at 11:07AM
3.25 or 3.50 will put a smile on your face. Smile
You can get FMX convertors, but shift kits, etc., not so much. FMX is kinda the unloved ford transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 16-December-2014 at 12:29PM
...  but shift kits, etc., not so much. FMX is kinda the unloved ford transmission.
still basic principals apply. remove the 'puck' from the VB, source good frictions & steels from the AOD section, cut a new snap-ring groove to add a clutch if there's room or the AOD clutches may be thinner so they'll fit more w/o moving the snap-ring. lighten or remove the accumulator springs, lighten or spring the governor, enlarge / chamfer exhaust ports, drill drums, widest possible band, shim the pump regulator spring... and it goes on
you can build a snotlocker FMX Wink
ramair351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2014 at 12:13PM
TCI makes a decent convertor, and you can get a nice shift kit too by transgo
http://www.drakeautomotivegroup.com/Store/Product/C9ZZ-7A100-SK.aspx?wid=141
i had a fmx built up for my 73, it was tough, and shifted nice
-Pete
1972 montego GT
1970 Torino cobra SCJ
1970 mustang mach 1
1965 Falcon futura
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 01-November-2015 at 3:10PM
all good info to know
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 01-November-2015 at 11:05PM
I got a Boss Hog converter in my FMX, night and day difference at the light. I couldn't idle the engine with the old one, now I'm fighting for traction.
antlerfiend View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote antlerfiend Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 2:05AM
I have two FMX trannys that shifted awesome stock. I switched to a C4 because of cheaper parts and lighter weight. Monster transmissions has a stall converter for FMX trannys. Put a stall in it and you will absolutely love it.
This page was generated in 0.068 seconds.
