  New Posts New Posts RSS Feed - steering column
steering column
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: steering column
    Posted: 22-June-2016 at 10:20AM
Do you have to remove bottom half of dash to remove column.I have it all loose but appears dash must come out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2016 at 11:26AM
No, lower dash stays in place. Just remove the gauge cluster(a bit of a job unto itself) to access the 4 bolts that hold the column to the brake pedal/steering column anchor system. You will also have to remove the shift cable, ignition switch wiring harness plug, the lower rubber dust boot to access the pinch bolt that retains the intermediate shaft(between steering column and steering gear) to the steering column's lower shaft. Probably left something out, but you get the idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2016 at 12:40PM
done all that,I think. No shift cable its floor shift. The collar wont come through. I can't turn it sideways to clear. Guess Ill have to get help.Thanks
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2016 at 2:47PM
I believe you have to compress the boot in order get it through the cluster opening
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2016 at 3:51PM
Even with a floor shift, I think there's a cable for the ignition interlock...
Could be thinking of G.M. though...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2016 at 4:14PM
if you pull the boot back to remove the pinch bolt the intermediate shaft should slide off the column, then let the boot slide off, rotate the column a little while lifting it upwards enough to work the column out, checking for things that catch on the lower mounting tabs as it comes out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 23-June-2016 at 4:07AM
Its out. Problem was age could not reach pinch bolt, so I removed rag joint. Ended up having to remove pinch bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-June-2016 at 3:26PM
Clap
This page was generated in 0.093 seconds.
