  New Posts New Posts RSS Feed - distributor identification help please ?
squarethumps View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote squarethumps Quote  Post ReplyReply Direct Link To This Post Topic: distributor identification help please ?
    Posted: 16-September-2016 at 7:24AM
Can someone help identify this distributor ? There's no marking for an actual manufacturer that I can see ?   It's the distributor that was in my 400 destroked to 351 rebuilt engine in my 1976 Ford Torino S&H.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2016 at 8:02AM
Not sure the manufacturer but there are several companies making those modified GM HEI to fit other vehicles good distributor but as far as actual manufacturer there are several companies out there making them and selling them
Post Options Post Options   Thanks (0) Thanks(0)   Quote squarethumps Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2016 at 8:09AM
Many Thanks for the reply
Any idea what it is worth ?
Are we talking 200 ? or 75 ? or ?
Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2016 at 9:35AM
You can pick them up new in the $50-60 range at some of the swap meets around here. Summit and/or Jegs frequently has them fairly cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2016 at 10:33AM
Yeah new $50-75 and up
Post Options Post Options   Thanks (0) Thanks(0)   Quote squarethumps Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2016 at 10:43AM
Many Thanks for all the replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2016 at 1:55AM
that may be a Procomp or Speedmaster (same) with the unusual slot in the bottom of the shaft for a 2 piece deal that holds the dizzy gear, I haven't seen one of those in a while
gotta wonder how that works out because the shaft is split, there's no stability from the top to hold the bottom, it relies completely on the pilot bore & the bottom stub of the 2nd shaft. the design does eliminate the precise measured location for the pin that holds the dizzy gear, the slot in the shaft allows quite a bit of slip up & down
Post Options Post Options   Thanks (0) Thanks(0)   Quote squarethumps Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2016 at 9:03AM
Here are some pictures of the gear. It just slides in. There's no way that I can see that holds it in place other than just the side effect of being placed together and trapped from moving.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2016 at 9:37AM
hmm, usually they are pinned.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2016 at 9:45AM
this slip fit design converts from the stock Ford design to the small mopar design style, I'm not sure how the big mop's are done. the bottom stub is doing all the work, running the oil pump off the cam gear, while the dizzy is just along for the ride
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2016 at 9:53AM
yeah i too was thinking mopar was like that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2016 at 12:35PM
Even thru the 2.2, 2.5 K-car engines, Chrysler was doing that. Stubshaft can be a real P.I.T.A. to get out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 22-September-2016 at 9:23AM
Looks like a procomp or similar China made.
This page was generated in 0.148 seconds.
