  New Posts New Posts RSS Feed - Remote oil cooler adapter
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Topic: Remote oil cooler adapter
    Posted: 21-September-2009 at 12:06PM
Hey gang,
My remote oil cooler adapter arrived today and was checking it against my block and it seems the adapter bolt threads into the block in the spot where the oil filter threaded nipple sticks out of the block. Is this nipple threaded into the block or will I have to have my block threaded for the bolt to screw into?
Thanks,
orlnslloyd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orlnslloyd Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2009 at 12:08PM
New guy here! And yeah, it's threaded into the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 13-November-2009 at 8:20AM
OK, tried to use two standard jam nuts to double nut and back the oil filter nipple out of the block but there is insufficient threads on the nipple to work. Any other suggestions on how to back the nipple out of the block without damaging the block or nipple?
Thanks in advance for your help!
interceptor460 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote interceptor460 Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2009 at 3:10PM
 Slice the nut in 2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2009 at 11:28PM
I thought about that but I wasn't sure if that would work or if there was a trick to unthreading the nipple from the block.
I'll give that a try and many thanks!!
This page was generated in 0.146 seconds.
