  New Posts New Posts RSS Feed - 1972 GTS side windows question help
SocalTorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SocalTorino Quote  Post ReplyReply Direct Link To This Post Topic: 1972 GTS side windows question help
    Posted: 26-March-2017 at 9:10AM
I need to install the complete 1/4 windows in my striped 1972 GTS, does anyone have pictures or a diagram?
I have all the parts and brackets
Thanks for your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2017 at 1:03PM
factory body manual, 1973 should be the same if you can't find a 72
they come on CD now too
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2017 at 1:28PM
No pictures or diagrams (but I did stay in a Holiday Inn Express last night) but I did recently install one of mine after having them apart for almost 10 years.
Five helpful tips:
1. It's a PITA
2. Bolt in the regulator first.
3. Do not leave the rear guide on the window. I found it necessary to install the guide after the window was in the quarter panel. Slide it on the roller first and then bolt to the window.
4. No matter how many times you try to insert that window from outside the car it's not going in that way. It will only go in from in the car.
5. Be careful with the headliner.
It's all I got. I hope that helps.
Edited by lynchster - 26-March-2017 at 1:28PM
This page was generated in 0.055 seconds.
