  New Posts New Posts RSS Feed - Bucket seat conversion
yellowsportwagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Topic: Bucket seat conversion
    Posted: 01-April-2017 at 3:23PM
Who has done a bench to bucket conversion?i need some answers concerning shifter wiring.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2017 at 4:40PM
you mean more like column to floor shift conversion???
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2017 at 6:12PM
Yeah that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2017 at 6:54PM
well from what i understand... there is a short wiring harness that connects the shifter wires to the NSS at the bottom of the column, or you can test wires and connect them yourself. my floor shifter had the wires cut off and the NSS was broken i used an AOD tranny so the NSS was inside the tranny so i just hard wired them into the wires from my old columnWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2017 at 3:47AM
I think I have that harness and I have the floor shift column.i guess I need to know if the rest of the wiring under the dash is the same.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2017 at 4:36AM
should be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2017 at 10:18AM
Sorry Tim, I really shoulda done a better job taking that harness apart. I'm sure these guys will know what goes where.
Matt
1969 Mercury Marauder 390
1972 Montego MX
2003 Mercury Marauder 300A
1994 F-150 5.8
2016 Ford Fusion Titanium
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2017 at 12:39PM
That's ok Matt I'm just making sure I have everything I need before I make a mess of this thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2017 at 6:14PM
On the floor wiring harness, doesn't matter column or floor shifter, the harness has a wire looped that will interrupt the starting circuit. On a floor shift car that wire is plugged into the harness and ties to neutral safety switch.
On a 4 speed car, that wire is merely looped as our cars don't have a neutral safety clutch switch to prevent bump starts with the car in gear.
Under dash won't matter, it's all in the floor harness.
I'm sorry but I don't have any pictures for you to be able to reference at this time.
