  New Posts New Posts RSS Feed - Big alternator or little alternator...
Turbo301 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Topic: Big alternator or little alternator...
    Posted: 21-November-2009 at 5:36AM
Does anyone know how to ID whether or not a car (in this case, my '77 XR7) has the optional high-current alternator? They apparently require different drive belts, and I didn't want to buy the wrong one, but I don't know how to tell which alternator I have. Given that my car has very few options, I'm betting it has the small one, but then again being bought in Ontario it may have been "winter equipped", so to speak.
Did the high-capacity alternator come standard with rear defroster or any other electricity-hungry options?
Thanks for any help!
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
72sport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2009 at 5:56AM
The high current alternator has a plug that plugs into top of the case + the large diameter charge wire.  The base alternator all the wires have their own terminal and are on the back of the case.  Post a pick and we can tell you wich you have.
Tom
Tom
1972 Gran Torino Sport 4Spd
1974 Montego wagon "GT" with GT hood, correct buckets
seats, console, and floor shift
2013 Focus 5 speed- Daily driver
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2009 at 9:34AM
if you pull the alternator, the amperage rating should be on the case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2009 at 1:07PM
Wow, I'm a dumb-a$$ :D. It's amazing what a photograph will tell you. I took a shot with the flash on and saw "15 V, 70 A" on the case; I never noticed this when examining it under regular lighting. Can you guys confirm that this is what you'd expect a 70 A alternator to look like? Is that a stock size and basic configuration (one never knows what parts get replaced over the years)?
Thanks!
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2009 at 3:37PM
Yeah, thats the high current alternator.  With no power windows it probably got it because of the rear defrost or it may have been optioned with it, but either way it looks stock and original.  The alternator on my wagon is a remained unit and it no longer has the amp rating stamped on it.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2009 at 2:45AM
I see an antifreeze puddle there..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2009 at 2:55AM
Yeah, I had the rad flushed before putting it away, so I think some slopped. Come the spring I'll keep an eye on it to make sure it's not leaking ^_^.
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
This page was generated in 0.159 seconds.
