Instrument cluster changeout ... |
| Author | |
Fordified V8
Joined: 07-November-2009 Location: midwest Status: Offline Points: 59 |
Topic: Instrument cluster changeout ...Posted: 24-November-2009 at 2:19PM |
Does anyone have any insight regarding an instrument cluster changeout?
70 MACH I "R" code
72 GTS 351CJ 72 TR6 15 F250 Lariat |
ramair351
Joined: 08-May-2006 Location: west michigan Status: Offline Points: 1561 |
Posted: 24-November-2009 at 2:25PM |
i'm in the middle of one. take the top pad off. look for screws at he front edge and on the sides towards the doors. drop the shifter into 1st gear and take off the black cluster bezel after removing about 8 more easy screws. then you will see how the cluster comes out. be careful the white plastic is fragile.
-Pete
1972 montego GT 1970 Torino cobra SCJ 1970 mustang mach 1 1965 Falcon futura |
ramair351
Posted: 24-November-2009 at 2:26PM |
sorry you have floor shift, disregard the shifter comment.
-Pete
GranTorinoMan
Joined: 14-August-2005 Location: Canada Status: Offline Points: 920 |
Posted: 24-November-2009 at 2:44PM |
The easiest way to take it out is remove your top dash pad and the front cover which are held by screws. You can reach in from up top to disconnect the Molex Plug and unclip the speedo cable.
You'll need this Molex Plug with the Sport Gauge Cluster, make sure it all comes as a package when you buy your Sport Gauges.
![]() Edited by GranTorinoMan - 24-November-2009 at 2:56PM |
Fordified V8
Posted: 24-November-2009 at 2:51PM |
sweet mural GT Man, thanx
70 MACH I "R" code
Posted: 25-November-2009 at 6:11AM |
OK, stupid question, isn't the red wire with yellow hash marks a resistance wire?
I know in the main harness going up to the dash, there is a wire coming off the firewall block that must not be cut.
I spent way to many hours piecing back my harness so it was good. Then I had to go and do something stupid like add extra power circuts and move wiring around.
DOH
ramair351
Posted: 25-November-2009 at 6:36AM |
the resistance wire goes from the ignition switch to the firewall i think it was yellow/red
-Pete
Psquare75
Member of the Stroker Club Joined: 26-November-2005 Location: United States Status: Offline Points: 4591 |
Posted: 25-November-2009 at 7:03AM |
THe red and yellow wire should just be the power wire for the cluster, 12v+ with ign and start. I'll try to take a pic of my FSM when I get home from work.
SquireCJ
Joined: 23-October-2009 Location: California Status: Offline Points: 319 |
Posted: 25-November-2009 at 10:09AM |
Here is an excellent tech. link on the '72-'79 Gauges.
http://www.ranchero.us/forums/showthread.php?t=8411 |
GranTorinoMan
Posted: 25-November-2009 at 5:41PM |
It doesn't get any better than that, talk about detail.
GranTorinoMan
Posted: 25-November-2009 at 5:45PM |
That Ranchero forum has some dedicated owners, extremely thorough.
Fordified V8
Posted: 26-November-2009 at 11:48AM |
thanx for that, I actually came across it recently. very thorough.
there are a couple of holes in it, just trying to see if there are any hidden nightmares. |
70 MACH I "R" code
