  New Posts New Posts RSS Feed - Drilled and Slotted help
Good Guys View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Guys Quote  Post ReplyReply Direct Link To This Post Topic: Drilled and Slotted help
    Posted: 10-December-2018 at 4:02PM
OK so working on a 1973 Torino its a 351w car we are doing a complete restoration of the car and have run into a problem with the front brakes . We upgraded the rear drum brakes to drilled and slotted disc brakes and would like to add drilled and slotted to the front to match the rear . problem is we are on our 3rd set of rotors that will not work , the 1st set was from stop tech , the summit web site said the would fit 1973 torino but when we got them they where not the same height and when the spindle nut was all the way tight the rotor was still loose the hub was not wide enough , and the rotor disc was not as thick as the stock rotors . called stop tech they said we don't make rotors drilled and slotted for 73 torinos . The next set was from SSBP called them they said yes we have what you need , ordered them up , but when we got them they where the same as the stop tech the hub was not wide enough , the next call was to baer brakes , I gave them all my measurements and he had rotors that matched exactly !  Ordered them up had them in 4 days but still no go . The inside wheel bearing cup is bigger and the 73 inside  bearing is to small . So ya figured out that it is a late 73 - 74 rotor with the bigger inside bearing , but of course their is no bearing to fit the bigger cup and the smaller spindle shaft .  so from what i have read if we find a set of 74 spindles we should be able to make these rotors work . So long story long am i correct in that thought that the 74 spindles will fit our 73 with the 74 spindle having the bigger inside bearing and it should fit the 73 ball joints and tie rods ? Any help is much appreciated !
James Andrews
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-December-2018 at 4:23PM
ahhh! sounds like you have the older 72 style small bearing spindles? yes 74+ ford cars used the same later standardized bearings. IDK if i have any more 74 spindles off as i've sold a couple sets... i do have another pair on a car but i need to keep it moveable until i have the motor sold...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Guys Quote  Post ReplyReply Direct Link To This Post Posted: 10-December-2018 at 5:23PM
Ok well I need to try and find a set so we can continue on with this project so if you know anyone that might have a set let me know . thank you
James Andrews
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-December-2018 at 5:28PM
ok
74-79 torino, t-bird, cougar, montego, ltdII should all be the same spindles...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 11-December-2018 at 5:29AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 11-December-2018 at 12:10PM
It sounds like you need the big bearing Spindles and all should work fine.  Please post some pics of your work, we'd all like to see the setup.
Check out this thread here, it has all the part numbers for spindles and bearings and which cars you can get them from:
7T9_Tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 12-December-2018 at 2:18AM
Found these on Ebay, as an alternative if the spindles don't work out.
According to the seller, the picture in the ad is a stock photo, and the rotors shipped are supposed to be 100 percent bolt-on.
John
73 Gran Torino formal roof
79 Thunderbird Heritage
79 Thunderbird Town Landau
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Guys Quote  Post ReplyReply Direct Link To This Post Posted: 12-December-2018 at 3:48AM
Ok thanks guys for the help I will get some pictures up soon . We found a u - pull -it lot that looks like they have 4 -5 cars that should have the spindles that we need , going Saturday am to check it out .
Hope there is something left .
Thanks
James Andrews
This page was generated in 0.064 seconds.
