  New Posts New Posts RSS Feed - Rear axle bearings-Timken or SKF?
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Topic: Rear axle bearings-Timken or SKF?
    Posted: 24-December-2018 at 2:43PM
SKF are $5 more each at Summit, but wondering which is really better, if there is even a difference?
Thanks,
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 6:46PM
idk SKF are good but timken are too
 i think i'd go with timken for the rear axle
 i did on my original rear end but swapped to the lincoln disc later it used different style bearings
 i went with timkens on my 4x4 blazer because i read that they were the best available for that as those are a non serviceable hub style Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 7:03PM
Thanks.
I just ordered the Timken ones. If for no other reason than I used to drive by the factory in Ohio fairly often. And your recommendation. Clap
Seems both are about the same, so might as well save $10.
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 7:33PM
yeah why not. SKF does make bearings for most anything and they are good quality! i only buy skf for any of my tools like sanders, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 10:27PM
FWIW,
I second what CJ said, both are very good bearings and you can't really go wrong with either choice. If you do choose Timken, do not be surprised to find Koyo brand bearings in the box, which are said to be as good or better than Timken.
Edited by aquartlow - 24-December-2018 at 10:27PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 25-December-2018 at 3:14PM
Thanks, again.
Sometimes having a bunch to choose from makes life hard. LOL
Russ
Edited by russosborne - 25-December-2018 at 3:14PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-December-2018 at 3:53PM
russ, i PM'd you i found that water neck for you Big smile
