  New Posts New Posts RSS Feed - installing trans crossmember
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Topic: installing trans crossmember
    Posted: 30-March-2019 at 2:21PM
I am putting my tranny back in (73 torino 429 c6) and the shop manual says to attach the trans mount to the crossmember and then install to the tranny.  In doing it this way there doesn't seem to be enough room between the crossmember and the tranny to get a wrench or socket in to tighten the bolts to the tranny.  Any suggestions would be greatly appreciated.
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-March-2019 at 3:29PM
with the tranny bolted to the block... do you have enough room to get the cross member up on top of the frame pads with the mount bolted to the tranny first then jack the tranny up until it hits the tunnel ...is there enough room to get the cross member up in there clearing the mount studs??? i think that's how i've done it....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 30-March-2019 at 3:44PM
There is a little room left above the tranny, I will try jacking it up more and see if that gives me enough clearance with it bolted to the tranny first.  I know it will probably be a tight fit but hopefully that will work, appreciate the response John
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-March-2019 at 4:50PM
 if not plan "B" would be put the crossmember up in there with the mount sitting in the holes and lift the mount up by hand and start the bolts in the tranny and tighten with a box end wrench then double wrench method for torque Wink then lower it down on the cross member, install the nuts on the bottom... i've done things like that before PITA but....
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 30-March-2019 at 6:26PM
We used to just rotate the crossmember to get it on the frame after the trans and mount were installed already. (Aamco 1984-8)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2019 at 5:42AM
When I installed mine, I bolted the mount to the transmission first.  Then I used a floor jack to lift the transmission as high as it'd go and installed the cross member and dropped the transmission.  I had no clearance issues doing this way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2019 at 9:30AM
OK, got it in, as suggested raised the back of the tranny as high as possible and then rotated pass side forward and drivers side to the rear (read that from an earlier post by TV2M80). Actually went back in pretty smoothly. Thanks to all for the help. - dave
This page was generated in 0.074 seconds.
