  New Posts New Posts RSS Feed - Refurbishing aluminum slotted mags
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Refurbishing aluminum slotted mags
    Posted: 01-December-2009 at 6:32PM
Just got my 15X10 aluminum slots today and they were a little ruff.
They have scratches and some nicks and dings in the aluminum but I didn't pay nearly what other  15X10 slots have been going for on ebay.
 So I was working late tonite painting a Dodge Caravan at work and in between I started sanding down one of the wheels to remove the scratches,nicks and dings on the aluminum wheel.
I started with 180 grit on a 6in DA sander to remove the heavy scratches and deep nicks in the metal and smooth it out.I then switched to 320 grit on a DA, then 500 grit.I also have a 3 in DA sander which is great for the center of the wheel and tight areas.
Next I start wet sanding by hand with 800 grit wet/dry sandpaper removing the heavier scratches left from the DAsander then I switch to 1000 girt wet,then 1500 grit. I still have to remove some deep nicks in the metal but wanted to see how the wheel would polish up.
had I been done completely sanding I would finish off with 2000 grit wet before polishing with compound on a 3in buffing wheel  then use a polish glaze with the buffer and sponge pad to really polish to a high shine and minimal swirls or ultra fine scratches.
You can also finish polishing with a metal polish to get a real deep mirror finish.
I'll post some before and after photos but the polished wheel is not finished yet and needs more sanding but just wanted to show the difference from before and after sanding and polishing.
Before
deep scratches
Edited by 73 ProStreetTorino - 01-December-2009 at 6:41PM
occupant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote occupant Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 2:09AM
oooh...shiny pretty things...*drools*
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 2:56AM
Sweet! Those look great. Gonna clear em?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 5:36AM
Damn Jeff...coming along smooth.
I guess I would not have thought to sand them like that. I'm a bit of an air tool freak and would of gone the surface conditioning route and then power buffed the bejesus outta them.
What's sad is at the north end of my block there is a VW dune buggy and guess what it's sitting on?
Been there at least 20 years and not moved.
They are 15x10's as far as I can tell, but deep offset.
Edited by Eliteman76 - 02-December-2009 at 5:39AM
ramair351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 6:34AM
looks like SpeedBuggy, does it talk?
-Pete
1972 montego GT
1970 Torino cobra SCJ
1970 mustang mach 1
1965 Falcon futura
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 7:29AM
HAHAHA
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 8:54AM
vroom a zoom zoom!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 12:50PM
Ha...I think it gave up the ghost a long, long time ago.
Nothing one of my 351c 2v / fmx combos couldn't handle...Evil Smile
BIGEMUN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIGEMUN Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 2:09PM
Awesome, trash to treasure at only the cost of a ton of elbow grease!
Great job!
Andy- pick that vw up! I saw this one this summer at a car show- I told him it needed a huge whip and coon tail! Took half the afternoon to get a pic. without anyone around it.Way cool!!
1975 Gran Torino Sport
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 2:38PM
ok lets get back on track
No I'm not going  to clear them as it gives it a dull finish when you clear aluminum wheels.you get more of a mirror finish from just polishing them with metal polish
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 5:26PM
I didn't save the link but, there was a discussion about polishing rims before.
I followed the link and it took me to a site that showed...
Sand it down and then apply the sealer/primer and then the polish and it was supposed to be a super tough finish that DID NOT DULL!
Wish I saved the link!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2009 at 5:40PM
Zoop metal seal had a deal...something with their chemicals they use.
albo74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albo74 Quote  Post ReplyReply Direct Link To This Post Posted: 13-December-2009 at 8:00AM
 I wanted to get some mags,  re finshed down town , they told me to take the tires off.  no problem, now they won't even return my phone calls. Whats wrong with people these days.
albos73gts
Post Options Post Options   Thanks (0) Thanks(0)   Quote albo74 Quote  Post ReplyReply Direct Link To This Post Posted: 13-December-2009 at 8:01AM
 gee
Edited by albo74 - 13-December-2009 at 8:03AM
albos73gts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 13-December-2009 at 9:33AM
my 10x15s are on the way from Uante!
Gonna throw some meats on them to get pics and measurements!
I have some REALLY slicked 295/50/15's I save from my Dakota. The PepBoys Futura's.
Just to put them on and see what it looks like.
Then of course when I paint the car I will back paint the slots and backside to match.
OLD SKOOL look!
This page was generated in 0.100 seconds.
