  New Posts New Posts RSS Feed - ford ranger
ford ranger
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: ford ranger
    Posted: 04-October-2019 at 11:30AM
Ok having no luck finding rad core support bushing for my 02 ranger. Eng suspension only goes to 98.Auto zone same ans. Anybody better than me could use help. I destroyed old one thinking this was a simple find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2019 at 3:34PM
that's not that old... you should be able to find a good one at about any wrecking yard Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 3:29AM
have the radiator core support want the bushings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 6:31AM
no i meant go to pick n pull of something and remove some bushings, that's fairly new so there should be some of those trucks in the yard and they should have good bushings still!
 unlike our 45 year old cars Confused
i don't have any of those bushings BUT i do have a perfect hood and tailgate for a 2000+ ranger Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 6:58AM
far different geologic / climate / corrosion conditions from where you are Johnny
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 9:27AM
true! but i'd think it's new enough the rubber would survive?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 9:42AM
must be the hole in the ozone?
why not just find something from Energy Suspension and get on with life?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 9:48AM
They have only up to 98 called them. not knowing difference I did not order. Auto zone said same so did summit and jaz.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 9:51AM
reverse engineer them,
how tall?
outside diameter?
inside diameter?
you can use anything from shelf stock that's close, shim them up or cut them down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 9:57AM
Dorman has all sorts of bushings, again you can shim or cut for a custom fit
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 10:00AM
went back to energy suspension asked about body mounts.maybe calling it a radiator core support was wrong question see monday
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 10:08AM
they have a body mount kit, that doesn't cover the rad core support mounts?
lazy B's, they should break a leg figuring it out if they don't cover the application
millions of those running around out there
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 12:18PM
If only I had not cooked the old ones getting them off. Never though I would need them. I do have a parts truck will remove those and try to match to something thanks for thoughts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2019 at 1:39PM
Maybe look at Exploders and Sport-Trac Exploders as well.
Sport-Trac is a really a 4-door ranger
This page was generated in 0.072 seconds.
