  New Posts New Posts RSS Feed - Tach wiring with MSD?
neejah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote neejah Quote  Post ReplyReply Direct Link To This Post Topic: Tach wiring with MSD?
    Posted: 28-December-2009 at 11:47AM
I just wondered if anyone had managed to connect their standard Sports pack instruments to an MSD system.
Basically, I've started wiring as per - http://www.ranchero.us/forums/showthread.php?t=8411 , running the tach in series........so from the ign switch it runs through the tach then to the + side of the coil.
But, the MSD system takes a signal from the ign switch to power the box..........and an external supply to send a signal to the coil. So if I connect the wire from the tach to the MSD I'd expect I'll see nothing on the tach.
If I run the output from the MSD to the coil through the Tach - would that work? (MSD state nothing other than the MSD to be connected to the coil).....so I suspect not......
The MSD does have an output for a tach, but it's a single wire and I would suspect designed to work with a parallel type tach?
Just wondered if anyone had done it?
Thanks
Neil
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2009 at 12:53PM
Nope. But feel free to fill me in when you figure it out. I may go that route with the Ranchero.
Edited by lynchster - 28-December-2009 at 12:53PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2009 at 5:26PM
parallel, as in, the tach has + - and 'tach' signal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote neejah Quote  Post ReplyReply Direct Link To This Post Posted: 29-December-2009 at 3:28AM
Yes, I'd assume so - i.e the tach is powered externally......and the tach receives its signal from the MSD box...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 29-December-2009 at 3:32AM
Well, I believe the older Torino indash tachs go 'in series' in line. The later cars (My Cougar), have a parrallel setup like I described.. I have my factory tach running off the MSD box.
GranTorinoMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoMan Quote  Post ReplyReply Direct Link To This Post Posted: 29-December-2009 at 6:47AM
I tried to run the factory tach and my Haltech EFI off the same HEI designated tach wire and my EFI wouldn't run. The factory tach takes a lot more juice than the aftermarket ones. My EFI fired right up after I disconnected the factory tach and hooked up an Auto Gauge tach instead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote neejah Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2010 at 9:08AM
Thanks to all that contributed - and a happy new year! Got it sorted - I think!
You need an MSD Tach Adapter 8920........basically it's for a current sensing tach, the MSD website had all of the data sheets for their adapters........just need to finish off the rest of my dash re-wiring.
This page was generated in 0.154 seconds.
