  New Posts New Posts RSS Feed - Window
Window
Spencer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spencer Quote  Post ReplyReply Direct Link To This Post Topic: Window
    Posted: 05-March-2020 at 1:32AM
I've been working on putting my window in and it wont stay in the sleeve. It keeps falling out and when it does the track that lifts it falls off the pole that gides it. Any suggestion?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2020 at 2:57AM
 what year?
pete rad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2020 at 10:28AM
1968
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spencer Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2020 at 3:42PM
ya it's a 1968
papadeath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote papadeath Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2020 at 10:20AM
MAke sure u cover that glass well with something so it doesn't get scratched or chipped. Glass has always been a PITA to put in. Best of luck.
75 Ranchero in progress
04 Harley Deuce stage one kit
89 Toyota pickup modded
skateboard
4 bicycles
1 scooter
2 dogs
2 stupid cats
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2020 at 1:31PM
i'm not familiar with the inner workings of the first or second gen carsEmbarrassed the 72+ cars use a pole for a track and have plastic guides that run on them but i'd guess 68 may be similar to my 68 mustang it has a front and rear track no pole so hopefully someone else here can help???
unless the plastic roller at the end of the regulator arm is broken or missing then the window could fall out from the track
Post Options Post Options   Thanks (1) Thanks(1)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 08-March-2020 at 6:00AM
Here's some pics from the assembly manual.  They are a bit 'busy', but maybe you can save & zoom in on what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-March-2020 at 7:11AM
 Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spencer Quote  Post ReplyReply Direct Link To This Post Posted: 09-March-2020 at 10:50AM
thanks everyone for the help and suggestions. The  assembly manual helped out alot. I noticed that one of the screws on my track that holds my glass was set wrong. I'll make sure to cover the glass while setting it also
This page was generated in 0.105 seconds.
