  New Posts New Posts RSS Feed - Holley choke horn
Holley choke horn
Iain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iain Quote  Post ReplyReply Direct Link To This Post Topic: Holley choke horn
    Posted: 22-March-2020 at 9:20AM
Thought I'd ask a (maybe obvious) question. Has someone removed the choke horn thing, why would you do this, and it it a thing to do for some reason?
7T9_Tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 22-March-2020 at 10:01AM
Smoother airflow into the carb, usually for a competition engine.
John
73 Gran Torino formal roof
79 Thunderbird Heritage
79 Thunderbird Town Landau
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 22-March-2020 at 11:12AM
the only good reason to remove the choke tower is if there is such little hood clearance that such a low profile air cleaner is needed and the lid would restrict air from getting into the carb ... otherwise it's just another errant & detrimental modification
best power is made when the air is directed straight downward through the carb, air does not like to turn 90* for no good reason. carbs work best with linear air flow, non-linear air flow just causes a big mess over the air bleeds and venturi booster clusters. Big Swirling Mess if that conjures up a visual.
straight flowing air is Nice, turning air is a Big Swirling Mess
we know this from the air filter shoot-out, a salad bowl and a velocity stack won!
take the filter off the salad bowl and what would happen?
Iain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iain Quote  Post ReplyReply Direct Link To This Post Posted: 22-March-2020 at 10:39PM
Looks like there has been some butchery going on then.
Will get it set up and looked at this year at some point,, if not just to reduce the fuel comsumption!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2020 at 2:14AM
when i first saw your pic i did a double-take, it seems we have twins
Holley carbs are said to be 'a calibrated fuel leak' but the Holley style do make the best power Big smile
Iain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iain Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2020 at 7:53AM
It does look related there! It works, very well too judging by the way it pulls, but the fumes from the exhaust are eye stingingly bad. Going to look at a few things.
Drop the fuel pressure a bit, and check the dizzy vacuum.
Leaking power valve has been mentioned too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2020 at 10:53AM
a couple of us in our old crew had a mantra saying,
It's Not So Much The Smell But The Burning Sensation In My Eyes
i don't know if it was rich or lean but that Pontiac could clear the mosquitos
and he had the kickdown cable routed to under the dash so he could pull it himself,
it would bark Desert Duelers on the highway
Edited by Rockatansky - 23-March-2020 at 9:24PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2020 at 3:58PM
your vacuum to the dist. should be hooked to that capped off port on the passenger side front of the carbWink
Rons73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rons73 Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2020 at 2:46AM
Not sure what dust and debris you have on your roads, but one thing I see on those conversions is they forget to seal up the little hole where the choke linkage passes through into the air horn area.  On passenger side and kinda in line with the front barrels. I drive on lots of dirt/gravel so I am always watching for where dirt can enter my engines.  Cannot see on your pic if it is blocked, but on Rocks pic the hole is open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2020 at 9:50AM
i have a custom 830 that has a chunk of brass stock wedged into the plastic slider retainer fingers,
it's about the same size as the plastic slider but just thick enough to be driven in
