Tach/Ignition problem |
| Author | |
farqs29
Joined: 14-July-2018 Location: Elmhurst Status: Offline Points: 16 |
Topic: Tach/Ignition problemPosted: 25-May-2020 at 5:47AM |
Hi everyone-
I just hooked up a vintage sun super tach to my 69 428 and got in to start it and the car won't start. It turns over but seems like there's no spark? I ran green wire to coil, white to ground, red to power and black to lights. When I disconnect the coil wire, the car starts up and runs fine. It shouldn't be an issue with the tach as it was recently rebuilt. Any thoughts on what the issue might be, and how to fix it, would be greatly appreciated! Thank you in advance!
farqs29
Posted: 25-May-2020 at 5:52AM |
One more thing - the car has a mallory unilite distributor and a mallory promaster coil. Not sure if this matters, but thought I'd mention it. I will eventually bring it back to original coil and distributor but haven't gotten there yet.
Posted: 25-May-2020 at 6:40AM |
do you have a diagram for the wiring? idk sounds like a wire or 2 are wrong.
green generally goes to the coil (- i think? ) are you sure wht is ground? and blk is the light? |
Posted: 25-May-2020 at 7:09AM |
ok i found this...
blk= ground red= power green= neg side of the coil wht= light which sounds correct from my memory as well https://itstillruns.com/wire-sunpro-tach-7962668.html |
Posted: 25-May-2020 at 8:10AM |
White is dash lights Green is coil - Red is ignition power Black is ground
farqs29
Posted: 25-May-2020 at 8:12AM |
Thanks so much... I will give this a shot... I hooked black up to the lights as the black wire is the wire that comes from the light bulb in the tach. I figured the white wire must be the ground.
Posted: 25-May-2020 at 8:21AM |
what you see in front of you is more important than a diagram i found on the interweb |
Posted: 25-May-2020 at 8:27AM |
here's another
farqs29
Posted: 25-May-2020 at 10:49AM |
Thanks guys. The diagram helped... I pulled the tach out of the housing and the white and green wires were crossed on the back of the tach. I changed the wires and that solved the ignition problem, but the tach isn’t working!!
I ran the power off of the wire to the power antennae. Just tested it and it’s hot when the ignition is on. When I turn the ignition I see the tach reset at zero, but nothing afterwards. Does this sound like an issue with the feed from coil or main power? Thanks for the help. I definitely need it!! |
Posted: 25-May-2020 at 12:26PM |
Do you have the green wire connected to the negative coil terminal? The tach just reads how often the coil is discharging, so if your car runs there is no issue from the coil. It's got to be in the tach or your wiring to the tach.
Posted: 25-May-2020 at 3:32PM |
red should be powered with the key on! power antennae wires usually only power up with the radio on
or basically to the positive of the coil with the green trigger wire to the negative of the coil.and the coil needs the ground wire hooked to ground the trigger wire only senses the pulses it requires all 3 to work the light wire is optional... |
farqs29
Posted: 26-May-2020 at 10:26AM |
Thanks for the input guys. Yeah, I have the green wire hooked up to the negative side of coil and the red wire (power antennae, has a manual control switch) is hot when the key is turned on... confused, I guess it could be an issue with the tach, although it shouldn't be as I just had it rebuilt. Might have to call the folks that rebuilt it
Posted: 26-May-2020 at 3:46PM |
that's kinda what i'm thinking too
farqs29
Posted: 27-May-2020 at 12:48AM |
Well looks like I figured it out... actually I can't really say that... Last night I was frustrated and pulled the tach and disconnected all wires to the back of the tach individually, cleaned the nodes and then reconnected them in exactly the same way I had them connected. Turned the key and it works! No clue... Thanks for the help fellas. Very much appreciated!
Posted: 27-May-2020 at 3:29AM |
Joined: 08-June-2019 Location: Florida Status: Offline Points: 2034 |
Posted: 27-May-2020 at 12:34PM |
It's called P.FM. I got my first lesson with it. In the military. P.F.M. will cure several electrical issues.
Posted: 27-May-2020 at 3:44PM |
Percussive
Maintenance? |
Posted: 27-May-2020 at 5:02PM |
