  New Posts New Posts RSS Feed - pinto
pinto
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: pinto
    Posted: 28-May-2020 at 3:26AM
It appears no one makes rear shocks for my cw wagon. Any body know how to find length and travel for them. Never should have thrown old ones away.Happens when other half asks why you save all this junk
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2020 at 6:18AM
Short of halving the old ones to measure, you could try to full compress the rear suspension and measure the distance between the shock mounts. That is your minimum compressed length.  Then let the suspension hang and take the same measurement for the extended length.
Do you know what the difference is between the wagon and sedan suspension?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2020 at 8:39AM
According to pinto club 2.5 in.shorter. It appears the shocks mount to a plate that mounts to the sub frame which I can't find. Probably went with the old shocks when Evonne cleaned garage for me when I was laid up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2020 at 10:55AM
yes, IIRC they bolt to a triangle shaped plate of the top. i haven't forgot about the sway bar...i'll have to get after sal again! Confused
FWIW i may get a CW for parts if i can catch the people there in town, i'm told no title just want it out of there???
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 30-May-2020 at 1:12AM
Looking through all the parts last night,not sure this will ever get done,I keep getting older,
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-May-2020 at 6:47AM
Confused i know exactly what you mean Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 04-June-2020 at 1:02PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 04-June-2020 at 1:48PM
thanks. Not sure but 77 uses ears at top and no plate. those listed have stem on both ends. It did give spec though that might help.
This page was generated in 0.074 seconds.
